Beginners Arcade Logic Probe guide?
strykr
1,351CR
This might be a bit much to ask, but was wondering if any of the more technically orientated members could write a a guide on how to use a Logic probe to fix Arcade PCBs?
I realise this is childs play for a lot of people, but for people with limited electronic experience it would be great.
For those valuable and rare boards it makes sense to send them off for repair, but for instance, I have a 1942 board that has gfx and sound errors, do I pay around £100 to get it fixed when I can buy a worker for around £70-90?
david_orton_2000
Green Mario
344CR
Hi Rich,
I do not have a guide to hand, and I am sure there are some on google and/or YouTube, however:-
Some logic probes vary, like having a switch for CMos and TTL. This is because CMos and TTL have different voltage levels, i.e. for logical 0 and 1.
One thing you really should get your hands on is a book/pdf with all the 74 series logic in and also pinouts for all cpus, roms, rams, etc.. This then gives you the vital info needed. (I'll add a link or email you my 74-series book!).
Also, you need to understand or learn to understand logic gates (and, or, not, xor, etc.).
Basically when using the probe (which often needs a +5v source to function), you will see:-
Low - 0
High - 1
Pulsing (like a clock signal for example)
Also you will here of 'floating', which is when the output or input to the logic chip is not high or low as expected (determined from the chip pinout/logic-map schem).
Further, sometimes an input or output may be stuck high or low for example.
-There are many repair logs out there which provide such helpful detail. :)
Of course, you will already have the schems for the pcb won't you! ;-)
This can get deeper and deeper, examining address lines, data latches/buffers, etc. however the logic probe is a very handy device used by all.
Sometimes you can 'chase' a fault around, as it may be generated further back, i.e. one chip is faulty, yet a fault appears elsewhere (as the incorrect data is now sent on down the path as it were).
This is why board repair is not easy and not quick, sometimes you can be lucky and other times find multiple faults all over. No 2 boards are alike!...and most being over 30yrs old too!
Anyway, hope this is ok to start you off,
"Happy Probing",
Cheers,
DaveO.
ben76
Hunts Spies
1,136CR
strykr said:
Cheers fellas, very useful!
Im guessing im buggered without the schems tho? I will dive into this when I get a mo.
ta.
Not necessarily they do help a lot though. The legs on the chip would still function the same, clock pulsing, etc. The schems would make it a lot quicker to trace back to the next chip/area, etc if needed
- Ben
