Blast City step down question
pobtastic
477CR
Not "should" ... "will" be fine
The cabs are like 150w rated. There's a guide somewhere?
edit: http://wiki.arcadeotaku.com/w/Beginners_Guide_To_Candy_Cabs
pobtastic2015-12-07 15:12:10
ar2r
147CR
Thank you for quick replay.
The cab is 100v but apparently is will support 100-120v therefore 110v should be fine
I have seen this article but though it is worth checking.
I have seen airlink ones and they do look a bit more decent.
would i be going for something like this?
http://www.airlinktransformers.com/japanese_voltage_converters/japan_uk_voltage_converters/UK-JA0500/
phillv85
490CR
I believe Blasts are rated over 300w. Should be a sticker on the back that tells you the rating.
EDIT: I highly recommend the airlink transformers as well. phillv852015-12-07 15:32:47
ar2r
147CR
I do not have it yet so not able to check but would like to be ready when it arrives
I found this in jap manual so it look like it is 143w
500w airlink should be more then enough then
cosine
14 (100%)
595CR
Mine is rated 284w, and I use the stepdown in the maplin link, had the machine for 3 years now, no problems whatsoever.
