Bomb Jack PCB problems
ActRaiser
3CR
Hi guys.. so a kindly fellow on Facebook pointed me in the direction of this forum when I asked about the following.. so I have high hopes someone here may be able to assist me! :)
I bought a Bomb Jack cab today.. it's a generic looking cabinet (2 x joystick and 3 buttons), bland marquee part... It works great though, apart from one thing - the graphics are a bit messed up.
There are no backgrounds.. meaning I am missing those lovely wonders of the world when I am collecting lit bombs!! The bombs also have a box around them, which goes grey (I can still see the points scored though) when I collect them.
I am totally new to this and it's very daunting looking at the huge PCB board in the back.. the previous owner said it worked fine then just one day started playing with the missing backgrounds.. so I am assuming it to be something on the board that needs cleaning, and hopefully isn't anything too serious.
There are wires everywhere in the back and I am not even sure how to get the board out of the cabinet.. Is this doable for a total newbie, or is it best to pay someone who knows what they are doing to fix it?
Also, with it being an old huge PCB board.. can I take this out and replace it with one of those cool 60-in-1 boards that has all the classics (including Bomb Jack) on it? I see it described as Jamma.. is that something different or can I replace an 80s PCB with a jamma board?
Any help on these matters would be much appreciated.. I'd love to get stuck in to restoring it and playing it this weekend, but I've got a stupid music festival to go to tomorrow.. grr! ;)
SUPERSPRINT
1,035CR
First thing is it boots and plays so you are in luck there. I would start by removing all the socketed chips very carefully, cleaning the legs with a rubber, again very carefully. Ease each chip up from either end tiny bit by tiny bit to avoid damage. Once done replace them again very carefully making sure you have them the right way, there should be on most chips a key, small half circle on the chip and on the board to show you which way it goes back in.
Be super careful and you should be fine. This would be the first thing to try. OR.. you could send it to some resident experts for repair.
ActRaiser
3CR
hey guys.. thanks for the info..
I had a look at the link with your details and I'm afraid it's like trying to read arabic to me..
I am happy to attempt cleaning the EPROMS.. but it would really help me if you could pinpoint for me which one(s) have background info as the numbers don't mean anything to me.
thanks
Shinydaz
814CR
If you want to play more that Bombjack, a multi board is probably your best option. If your going to be pulling chips out, beware of snapping legs and which way round they are located in their sockets, or you'll do more damage than good.
There is a 60 in 1 here with bombjack. Shinydaz2017-08-25 05:56:46
ActRaiser
3CR
Thanks for the link and info..
Why are these 60-in-1 boards so tiny compared to the enormous PCB board of my Bomb Jack game (and other old boards)? and it has what looks like a monitor VGA output on it, while my PCB appears not to..
Do I need special equipment, adapters, harnesses or anything to be able to install this small 60-in-1 board into my cabinet? Is any soldering or intense wiring required.. or is it simply a case of removing the old board and inserting the new one?
ActRaiser2017-08-25 09:15:51
940CR
60 in 1s are emulation boards and modern, bit like a tiny PC I guess with all the game roms stored in a tiny chip, bit like a memory stick. They can be used directly with a PC monitor or plugged into a Jamma connector much like a regular Jamma gameboard.
t-m
333CR
Your bomb jack board has a unique edge connector, not the JAMMA standard that the 60-1 board has so won't directly plug in.
However it's likely that your cabinet *is* JAMMA standard but has an adaptor to the Bomb jack board, so removing it will allow you to plug the 60-1 in. A picture would help determine which.
940CR
Sorry, yes quite right t-m, I was assuming your cab was Jamma (which is likely), but always determine the set up before plugging anything in, you don't want to fry any PCBs.
940CR
Pictures don't load, says it won't allow 3rd party hosting.
You can upload pictures here directly if they are under 2mb
t-m
333CR
I can't see an adaptor in the pictures, it looks like it's been wired with a Bomb jack edge connector. So it is possible, but you'd have to remove that and solder on a JAMMA one.
ActRaiser
3CR
Quick update..
Today I took out the board, cleaned it as best I could with cleaning solution (the same stuff I've used to clean console game carts etc for years).. the amount of grot and grime that came off the PCB was unbelievable! I then prized off every EPROM and cleaned them with the same stuff, then scrubbed gently with fine sandpaper as I had been recommended.. I didn't really expect it to be fixed.. in fact, I kind of expected to break it.. but lo and behold.. popped it back in and it works properly!! no more graphical glitches or missing backgrounds! I am well chuffed! :)
Thanks to everyone here who gave me solid advice.. I really appreciate the help and I am now looking forward to getting more hands on with arcade machines!
