Broken lethal enforcers gun
mx5dob
83CR
Hi all. My lethal enforcers gun broke last night when trying to plug it into a 'zero point' PCB.the trigger works but nothing happens in screen now. No shots are registered.
Just looked at the wiring diagrams and they look different. Is there a chance I've blown something?
The pins were mounted at an odd horizontal angle rather than vertical so may have damaged the 4 pin connector. Although it doesn't look bent
mx5dob2021-07-22 19:10:54
Mykill
229CR
The second pin on leathel enforcers is ground,2nd pin on zero point is +5 volts ,you have grounded the +5 volts
Pin 3 on both plugs is trigger
Mykill2021-07-22 21:33:27
Mykill
229CR
I think the guns are quite different, zero point has a moving hammer on the gun ,have you got a better pic of the zero point schematics, as for damage?
mx5dob
83CR
Nope. It's not in the manual. Both zero point and lethal enforcers PCBs seem to be working still so the prob must be with the gun
mx5dob
83CR
Mykill said:
Theirs a gun test menu on the leathel enforcers pcb
Tried that but none of the
squares/targets are shot when I point the gun. Screen flashes white when
trigger id pulled though so that at least still works
mx5dob
83CR
John Bennett said:
I'd take a punt it's the opto sensor that's popped as it was wired backwards. Can you open it up and get a photo?
Certainly. Thanks!
Is there anything im looking for such as burn marks?
5,332CR
So that’s connected straight to the gun cables?
Seems a prime candidate to replace then, I’m just not sure what the opto is - worth a bit of Googling - I see a few fix logs.
I have a pair of guns at home that look similar (not sure what they’re off) - I’ll dig them out next week and look inside. You can have one if we can’t source an opto.
mx5dob
83CR
Thanks man. That would be great!
I can't seem to find a part number for the optical sensor. Closest I can find us the whole replacement Suzo happ optical PCB for £30 shipped. Looks different to the konami one too.
