Bubble bobble bootleg - Black Missing
cathaldub
46CR
I Picked up a cheap broken bubble bobble bootleg. After cleaning the pcb and reflowing some joints and a couple of dead rims I have or should I say had it playing perfectly using redux roms. All was great for about 4-5hours play then all of a sudden the black turned dark blue in turn causing all the colours to be a little off.
See photos, at first I thought it was a rom issue but I've read and verified all roms.
Does anyone have any idea of what could cause such an issue?
I've read similar issues on Taito boards caused by one of the rams
RGP
Meeter & Greeter
2,039CR
I'm not an expert but i've seen a few issues like this either:
a) your colour PROM or colour selector circuit has gone wrong
b) the circuit that controls blue output to the RGB pins is leaky - usually there's some transistors and resistors involved in this bit BUT I think on BB boards they used that weird SIP package RGB thing - however, on a bootleg board this would be un-implemented I would imagine.
As a bootleg is unlikely to have schematics (that I know of) you might want to start by back-tracking the BLUE pin on the edge connector to its nearby components and see what is happening there - if you de-solder the BLUE from the output to your setup does the black return?
shep
377CR
Bubble Bobble and it's bootlegs have palette RAMs. There's a fair chance one of them has gone wrong. IC's 83 and 84 I think.
cathaldub
46CR
Cutting blue gives me back black, so am I to assume there is a fault along there rather than the ram?
I've no spare mcm2018s so ill try trace back that blue as far as I can and test all components along the way.
cathaldub2014-07-14 09:04:43
cathaldub
46CR
I'm hoping its not the ram as it was working fine for hours and I've no spare MCM2018 rams and they are pricey.
I've traced the blue back to the bottom board where it gets difficult to trace.
On the top board it only passes one resister reads OK and one capacitor. gonna spend a few hours on it tonight
cathaldub2014-07-18 14:03:44
