Cable clip help!
Bobbdobalina
146CR
Hi all, just wondering what everyone uses for clipping cables inside cabs.
Been looking for the white circular plastic spring clip that are original to a couple of my cabs with no luck.
Any help as always is much appreciated.
Cheers Martyn.
Bobbdobalina
146CR
These are the type already in the cab. It’s not the end of the world if I can’t get the same ones, would just be nice
Bobbdobalina
146CR
namfreak said:
I'm pretty sure they're called P Clips and are readily available in varying sizes
Google P clips to see what your options are
Thanks for your reply, im sure P clips are usually a copper clip covered in pvc that wraps round the cable and a fixing is used through the two holes.
These are plastic and are a spring clip. Admittedly they do look like p clips from the photo.
