Capcom cps boards
bonehead
I'll get pix tonight
50 (100%)
1,729CR
Does anyone fix the capcom cos bottom boards on games like street fighter 2 and carrier air wing?
I must around 10 faulty bottom boards with one fault or another. Most have no sound or tiny graphic glitches. Top boards ok as tested on working sets.
seanr28
9 (100%)
319CR
the ones with no sound only will be an easy fix, ones with graphics issues are not so easy as its usually the custom chips that have failed.
2,272CR
Don't want to seem to doom and gloom about these but a few years back I thought I'd let a couple of the pro repairers try to fix some of my A-boards, and after spending around £250 on repair bills and still not having them working 100% I gave up and sold my whole CPS collection (Had 17 of the set!) after 8 of the A-boards died over the space of a few months.
Best option is picking up Pang 3 and SF2 3-layer bootlegs, they all use the same A-board.
There's also 3 versions of it, a DASH variant which was the later revision, one that is longer than the b-board, and one that is shorter - that was the version that didn't fail from my lot.
VectorGlow
34 (100%)
900CR
I try to avoid them wherever possible - the main boards are a complete and utter PITA to do any diagnostics on relating to graphics faults.
caius
588CR
The culprit of issues on A-BOARD is always the same : the CPS-A-01 ASIC.When it goes bad, it can give differet symptoms : bad graphics, bad scrolling and also a black screen.
