Capcom CPS1 Kabuki
Monstermug
1,807CR
Apparently when the battery to the Kabuki dies, this 40 Pin dip IC becomes a standard Z80B cpu. Trying to find a working Kabuki IC found on these games:
Adventure Quiz 2 Hatena ? no Dai-Bouken
Ash*ta Tenki ni Naare
Block Block
Buster Bros
Cadillacs and Dinosaurs
Capcom Baseball
Capcom World
Dokaben
Dokaben 2
Mahjong Gakuen 2 Gakuen-chou no Fukushuu
Pang
Poker Ladies
Pomping World
Punisher
Quiz Sangokushi
Quiz Tonosama no Yabou
Slam Masters
Super Buster Bros
Super Marukin-Ban
Super Pang (Japan)
Super Pang (World)
Warriors of Fate
If anybody has one of these games that has been de-suicided to run without battery and don't mind just using a normal Z80b instead of the Kabuki Chip, please let me know, as I have a game with this IC completely missing and would like to revive it back to it's original state. Will pay of course.
For those that don't know it has KABUKI written on it and looks like this:
It is normally socketed too.
I'm not 100% sure that using a Kabuki from another game will work for the game I have but I am willing to take a punt that it will.
Monstermug2020-08-06 01:49:34
keropi
90CR
If you reprogram the kabuki with your game's key then it will work just fine - arcadehacker has released all info and programmer details a couple of years ago
Monstermug
1,807CR
Layer said:
You can resurrect Kabuki with Eduardo's tool : https://github.com/ArcadeHacker/ArcadeHacker_Kabuki
Or (on CPS-1 QSound) replacing Kabuki with Z80B, reburning eprom next to Kabuki with Dead Suicide Battery file, then rely with a thin wire Z80B pin 27 to eprom pin 30 (pin 30 has to be out of socket).
Does the resistor and cap need removing for this to work too? Also will I have to cut the trace on the q sound adapter? I rather not cut any traces to be honest which Is why I I am looking for a kabuki ic.
Layer
376CR
It's the newer and shorter dessuicide method, no need removing resistor or cap. No need to cut the track on the QSound adapter.
Layer2020-08-06 09:24:21
Monstermug
1,807CR
Thanks buddy for this info. Never knew about this method before! Definitely an option if I cannot get hold of an original Kabuki. That explains why that IC had solder on Pin 30 and hanging out of it's socket but no Kabuki Chip.
