Capcom cps1 pcbs repair
bonehead
I'll get pix tonight
50 (100%)
1,729CR
So I have asked before but will ask again.
Is anyone fixing these? I have so many faulty bottom boards, some have slight graphics errors and others have no sound.
Any leads would be good please.
Del Griffith
17 (100%)
844CR
The ones with no sound could just be the z80 if you’re lucky, It failed on one of mine. I think it’s a common fault as I remember reading the A board was designed for a z80a but they used z80b’s to cut costs.
Worth looking at if no one repairs them.
bonehead
50 (100%)
1,729CR
Ok cheers guys.
So I need to use a z80 a instead of the b?
Maybe I will try swopping out a good chip from a worker pcb to see if that helps.
lix
546CR
The graphic glitch issues are pretty much always the large Capcom ASIC so only repairable if you can get a known good chip, which is basically like rocking horse poo unless you've got other CPS1 boards with other fatal issues like tracks gouged. I have also found some of the graphics ram chips (the vertical HM53461) go bad on a couple, mainly on the earliest boards.
Sound issues, on the ones I've fixed in the past I've had Z80 go on a couple of them, also the 6116 ram chip connected to the Z80 on some others, and at least one board with bad sound code latches (one or both of the 74HC374 chips at 15G / 16G on the old revision boards). I don't think it matters what Z80 you use (as long as it's a 4Mhz+ version, so A or B), I think Capcom just had a batch of crappy Z80s.
So yeah there's a greater chance of success in fixing the boards with sound issues. I don't generally offer to repair boards for people any more as I rarely have the time, but I might be tempted to fix some CPS1 boards with payment being getting a working CPS1 board for myself, as I am a bit short on workers.
bonehead
50 (100%)
1,729CR
Hi, thanks for the information.
I must have around 10 non workers with different types of faults and I know it’s the bottom boards as have tried swopping out working ones.
Steve
cosine
14 (100%)
595CR
I have a CPS A board that suffered from garbled text, and someone suggested reflowing the pins on the A-01 chip. I did this and the board has been rock solid ever since. It's worth a shot if any of yours suffers from this issue
cosine2017-12-15 11:38:17
