Capcom CPS2 stereo
terminator2k2
327CR
Hi there, Ive just purchased and received a CPS2 super street fighter 2 A + B board.
I cant seem to get the stereo output to work.
I get audio from 1 of the phono outputs only.
ive gone into the game menu and changed to stereo and saved the option.
the jamma connection isn't wired up for audio.
ive even changed the plugs around to rule out the wiring.
have I missed something?
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
you need a RARE Q-Sound amp to get Stereo out of The Capcom Boards
once the amp is in place then in test menu you need to set it from jamma mono to Q sound stereo
silverfox07862015-05-16 22:07:17
2,265CR
Or a cab with a stereo amp built in. In my Egret 2 I just flick the switch in the cab to stereo, select stereo on the pcb and out comes lovely big sound.
terminator2k2
327CR
silverfox0786 said:
have you set it to stereo in test menu
the stereo should be working fine when setup correctly
in the set up menu (pressing the test switch on the side)
ive set it to stereo and monaural sound, makes no difference...
ive also changed the game mode and set to freeplay, and save the configuration.
all this works , but no stereo output...
ah well looks like ill have to leave it in mono...
2,265CR
Is your cab deffo set for stereo? If I have my cab switched to mono and a game set to stereo I get no output at all.
terminator2k2
327CR
hi there, at the moment im using a 26 inch lcd tv.
ive made up a jamma harness without using the audio output on the jamma, using the pinout in the super street fighter 2 cps2 manual.
ive made up a jamma to scart adapter which works very well.
ive taken the audio input to the scart and wired 2 phono plugs.
the phono plugs go into the cps2 board.
red - right channel , white left channel.
with both in , I get sound from left channel only,
when I swap them around , I get sound from right channel only.
so cabling is ok, and both left and right amplifier working as should be in the tv.
so there is no output from the right channel phono connector on the cps2 board.
if I switch to mono. Shouldn't mono only output from the jamma connector?
terminator2k22015-05-17 14:35:58
terminator2k2
327CR
Just an update on this, ive been having a read and seen a few folks having a few problems with volume etc.
So i decided to give it a try.
Holding volume down and powering on the cps2, keeping the volume down pressed for around 20 seconds. Then turn the volume back up.
This has done the trick and i now have stereo sound.
mathj
499CR
nice bit of detective work there, that's another problem fixed and catalogued here
math
