Changing cps2 b board
wonder bloke
45CR
Hi,
I have cps a and b boards and they seem to be bolted together with a bolt with the capcom "C" on the head?
Advise please on how to remove as I don't want to force it?
5,653CR
The bolt is only for the blue/grey/green B board.
Check the sides for some clips, and pull hard
2,265CR
The clips pull straight out with a finger on one side, thumb on the other. Might need a little wiggle side to side.
The A&B will still feel very solidly joined even after the clips are removed but will pull apart. They are quite sturdy so don't be afraid to use a bit of force.
wonder bloke
45CR
Thanks gents, I usually am a little impatient with things but thought I'd ask before I knack something up.
There apart now. There are bolts or pins as it says on the label, on both the a and the b boards with the seals intact. Do I take it this means the battery has never been changed?
5,653CR
Either never been changed or it was changed by Capcom and resealed.
Some possibility it was changed and someone other than Capcom reused the seals, but this is unlikely.
cosine
14 (100%)
595CR
Yup. Piece of cake to replace if you're handy with a soldering iron though.
Dan_k
Mo-derator kiss of death merchant
47CR
With CPS2 boards you don't need a donor battery (unlike CPS 1), the key is held for up to a day, although I wouldn't advise leaving it that long
As long as you can solder to a reasonable standard just remove the old battery and replace it, as a confidence check I always check that the 3.6v is present once Ive changed the battery before replacing the casing. Dan_k2014-09-26 08:44:34
