Finally got a full run on video. Final score 11 million.
I'll record it properly next time with all the view of the cab etc. as the TG record is 3.5 mil so this beats it by a long way.
[tube]_DIQ7tTTN9A[/tube]
Muerto2015-02-03 18:46:42
Chase HQ2 I sold, this cab stays here - until I find a cockpit anyway!griffo83x said:i thought you had sold your chase hq mate ?
It's a technique I learned after playing it loads and loads, what it does is drops your speed just a fraction enough that you don't have to brake. I only ever brake if I need to avoid a car or mistime a corner - rest of the time I use the gears.Kenth333 said:Do you use the shifter to keep it from sliding off the road? Never knew you could do that.
muddymusic said:It's a technique I learned after playing it loads and loads, what it does is drops your speed just a fraction enough that you don't have to brake. I only ever brake if I need to avoid a car or mistime a corner - rest of the time I use the gears.Kenth333 said:Do you use the shifter to keep it from sliding off the road? Never knew you could do that.
Hey thanks for the high score info on my first postMuerto said:Wow! - great score, please submit it to TG, then "Mr. theres a potential kill screen coming up" will be a WR poorer![]()
