Chase HQ 63s141 - help with programming
ar2r
148CR
Hi
I have Chase HQ board with road not working.
Narrowed it down to ic24 MMI63S141N
I have ordered blank chips and found out that I have no means of programming them.
when I insert blank one the road comes back but then the game is missing other stuff (graphics on the title screen etc.)
Is it even possible? If so can someone help with this?
5,332CR
If it’s a PAL to handle when to turn on layers, then yes it could put the road on and cover or disable everything else.
Do you have a dump of a good chip?
ar2r
148CR
unfortunately not :( nor can I find one
the closest I got to it was this mame repo
https://github.com/mamedev/mame/blob/master/src/mame/drivers/taito_z.cpp
anyone can help with the dump? I guess they would be able to program it as well
philmurr
48 (100%)
2,378CR
Google suggests it's a PROM, equivalent to an 82S129 which can be programmed by a number of programmers
I'm guessing the dump is b52-06.24
Macro
2,016CR
What are the exact part numbers of the blank chips - many places send you 'equivalents' which may work the same in circuit, but are not necessarily supported by the programmers. Then someone (near) can let you know if they can program them.
i.e. mine can do 82s129, but not the 63S141 you mention, even though it is compatible
caius
588CR
Here's attached an adaption of this BPROM into a GAL16V8.Burn the .JED onto a GAL16V8, then tie pin 8 to pin 10 of the chip (in order to route VCC), lasty install the GAL16V8 chip onto the socket with pin 9-10-11-12 hangin off the socket.Let us know if it works.
P.S.
Let me also know if 13 and 14 of the BPROM are tied to GND on your board.
https://www.ukvac.com/forum/data/uploads/1573/ChaseHQ_B52-06.24_GAL16V8.zip
caius2020-01-21 16:04:17
caius
588CR
Access speed of the GAL16V8 should not matter
Check if pin 13 and 14 of the BPROM are tied to GROUND
P.S.
Are you from Australia?
caius
588CR
I need just to know if pin 13 and 14 of the BPROM are tied to GROUND on the board.This is important to me since these pins and the two chip enable inputs of the device.If they are tied to GROUND my GAL16V8 adaption should work, otherwise I have to change the equations of the GAL16V8 fuse map.
Anyway, try first the .JED and let us know if it works.
ar2r
148CR
P.S.
In here do you mean ground instead vcc? Pin 10 looks to be ground on the gal pinout
