Chihiro Gpu fan
terminator2k2
327CR
i couldnt find one for mine and i didnt like the idea of putting a used fan in there as that could fail aswell with out knowing its history...
so i got a Noctua NF-A4x10 FLX Fan
when i took mine apart i noticed the original fan had been replaced any way, so used the mounting screws from the old fan to fit the new noctua fan...
FinalFight
73 (97%)
770CR
Thanka guys for the info if i cant get a new original i will swop it for the one terminator2k2 mentioned.. maybe its better than the original :)
Ste
vib_ribbon
488CR
yeah, should be the same as the xbox one iirc.
thing is, they dont need to fail necessarily for the gpu to fail. but of course, if they do fail then the gpu would normally follow.
FinalFight
73 (97%)
770CR
Yeah i think it is the same but some of them dont have a fan they have a bigger heatsink like the 2 i have here .. I want to just replace them asap as they will have been on since new .. would be good to pickup some that run alot cooler than the originalsstegrey2017-07-22 18:43:12
obcd
3,830CR
Wait, are you saying your chihiro's are having a big heatsink and no fan? I never heared of such setup before, so maybe the mobo's aren't original? The larger heatsink would come pretty close to the base board I assume. (At least it would if it's the same type microsoft used on it's 1.1 - 1.6 xbox mobo's. A 40 mm fan fit's fine on the original heatsink (with fan) They are sold as coolers for older pc vga cards. Can you check the mcpx chip on your mobo? Is that a rev. II or rev. III? Is the mobo power connector a single row or a dual row one? Some pictures of the mobo would be interesting as it's obviously something strange. I have a chihiro board with a dual row power connector that still has a fan. If the fan is doing it's work, it probably can keep the gpu cooler than the bigger heatsink. A chihiro runs it's game (in demo) all the time so it might need a bit better cooling than an xbox that is used for a couple of hours. Also, xboxes adjust the case fan speed where on chihiro it's running at full speed all the time. (The noise isn't much of a problem in an arcade.) I am working on using upgraded xbox boards in a chihiro setup, just to explain my interest in yours.
obcd
3,830CR
No problem. Only 1.0 xbox models had the smaller heatsink with the fan on their GPU. 1.1 - 1.6B models had the bigger heatsink without the blower. You can identify the type using the serial number as it has the manufacturing date embedded.
