Cleaning PCBs
philmurr
48 (100%)
2,374CR
Some people seem worried about cleaning dirty PCBs as they think they may damage them. So I thought I'd post how I've cleaned them for a lot of years without any issues. This post doesn't include removing flux etc. after repairs, it's just for getting rid of muck. Others just put boards in the dishwasher...
Notes - you may want to remove socketed EPROMs and mask off any stickers on the board (as the cleaning process can damage paper labels). You also may want to remove socketed chips to speed up drying (I usually only remove expensive chips like SC-01, the board below has a multigame so there are no socketed EPROMs)
So a fairly simple process:-
1 - add washing-up liquid and water and use a toothbrush to clean one side, then rinse under the tap
2 - do the same for the other side
3 - put board upright in the sun (if there is any) or just outside for a couple of hours to drain all the excess water off.
4 - if it isn't sunny or if it's cold move the board inside to the warmest place and leave for a few hours (definitely doesn't need more than a day)
5 - check to make sure it is dry, replace any chips you removed and power up
Here are photos of a Missile Command board I cleaned at the weekend, took a couple of hours in the sun then an hour in the warm network cupboard before powering up.
PCB Fairy Liquid.jpg PCB rinsing bottom.jpg PCB rinsing top.jpg PCB drying.jpg PCB bottom clean and dry.jpg PCB working.jpg
TheDaddy
14 (93%)
7,224CR
Someone had requested I post how I do mine , I was just about to do it ! lol
Prety much the same as you :--
The only real difference is drying time, I leave mine for 5 - 7 days to be sure and thats in the Airing cupboard (Warm in there).
I always remove socketed chips and work around Dip switches.
Dave.
Phils Arcade
1,529CR
I gave up on cans of compressed air some time ago and use one of these instead. Great for blowing out water trapped in little nooks and crannies, as well as blowing off dust.
Can get used up way too quickly. I use an air hose to the compressor in the shed. Had to fit a restrictor to it as it was a tad to rough in places.
Also as above, a hair dryer is good at removing a lot of moisture.
TheDaddy
14 (93%)
7,224CR
big10p
Coins detected in pocket!
6,081CR
I was actually pretty impressed with how long the rechargeable battery lasts, but it's not something I need to use for long periods on a daily basis.
