Cleaning sticky steering wheel!!!!!
bonehead
I'll get pix tonight
49 (100%)
1,712CR
Silly question but how do you guys clean the steering wheels on driving cabs?
I have picked up a sega driver and no matter how much I clean the wheel it stays sticky.
I have tried foam cleaner, alchohol and white spirit but still it is sticky.
It's on a crazy taxi cab.
big10p
Coins detected in pocket!
5,595CR
Coke? It's full of sugar so likely to make it even more sticky!
Maybe try sealing it with a polish like Mr Sheen applied liberally with plenty of elbow grease?
big10p2015-08-09 23:39:52
Mr20to5
1,331CR
I use a lot of car cleaning products for other jobs, mainly because I have a lot anyway.
Autoglym Intensive Tar Remover states -
Dissolves tar on paintwork and plastics instantly. Suitable for use on rubber, synthetic carpets & upholstery to remove oil-based stains. Removes tar, oil, grease, silicone, wax, gum, tree sap, fuel stains and adhesive residues.
(Other brands are available!)
bonehead
49 (100%)
1,712CR
I think it is a happ wheel!!! I will try the tar remover as I have some.
Thanks for all the ideas I report back what works.
Chopper79
665CR
Pole position steering wheels suffer with this. Got mine really smooth. I used label remover, and then some pledge. Foam cleaner is good for cleaning, and breaking down dirt, but wont remove stickiness.
davey d
478CR
ZedEx48K said:
I think it's actually just the age of it and the chemicals in the rubber slowly giving up, seen it on PC mice, car trims etc as well.
As above. I bet due to the age it's the rubber breaking down, so will always be sticky
big10p
5,595CR
You could always fit a tasteful cover. Something like this:
Ropi Jo
127CR
I got an old exercise bike where the grips were really sticky. I tried loads of stuff, including most of the above. Even when it seemed to work initially it was sticky within a week, so I agree it's just the natural breakdown of the material. I ended up just using grip tape as used on drop-handle racer bikes.
Sbdesign
SEGA collector
1,633CR
To bump this up…
I got a used amp with rubber buttons
They were sticky like a kids purposely sticky gel rubber toy.
The more I cleaned them the worse it got
Fibres from cloth stuck to them.
After reading up about window cleaner
I tried it and they got more sticky
Then read someone said keep changing part of cloth and rub hard.
I didn’t expect the results? But they are no longer sticky and normal again.
I’m sure I have a sticky wheel
Somewhere to try this…
It was driving me nuts
