Coin mech help please
musashi
13CR
Hi all, does any one know the significance of the settings on my coin mech board?
When £1 inserted in to my mortal kombat 2 machine keeps saying excellent x18 times before I get the game started.. very frustrating to wait for to stop and play the game.
Any help appreciated:
musashi
13CR
Thanks I have seen that swallowam site link but it doesn's show what the settings 1-8 are, instead it refers to R1-R4 which are not a dip switch?
I have checked the diagnostics and the credit is set to 1, the maximum is set to 30 but reduced that to 5 which hasn't done the trick.. any ideas?
Am just after a diagram with key which will be a massive help to show me what the settings are,
big10p
Coins detected in pocket!
6,094CR
I can't see any reference on that site to R1-R4?
Just had a quick look in MAME. Seems this game uses a 'units' system. Try changing all 4 chute settings to 1 unit per coin, then 'units/credit' to 1. I think this should give you 1 credit per coin inserted.
musashi
13CR
Thanks for that, all I can see is that blue dip switch on the coin mech with x2 on and x6 off. Is that what your relating to? or the dipswitch on the pcb? where can I find the chute settings? sorry still learning.
musashi
13CR
yes, I have been under custom pricing and set credits to 1 but it still carries on with 18-30 credits per coin?
I have tried the uk2 setting as well which should give 5 plays per pound but that doesn't work either?
big10p
6,094CR
Must be due to credit board setting then, I guess. Try setting DIP switch 6, 7 and 8 to ON. I *think* that will turn off bonus credits for inserting £1.
Is it only £1 coins that are giving the problem? Do 20p, 50p work as expected?
5,415CR
It says Mars on the pcb and this is the mars switch settings so currently set on 20 coin and bonus 1 on if that the correct one for it but this below says 9 switches
The credit board could be faulty, have you tried the pressing the button see if it does test credit
Mars Credit Board
Code:
All links 1 to 5 should be removed for UK use.
	The 5 way DIP switch is for enabling coins. Normally F,E,D and C should be ON and B should be OFF.
	Game Price.  SW1 SW2 SW3 SW4  Bonus 1  Bonus 2
	      10p     0   0   0   0
	      20p     1   0   0   0
	      30p     0   1   0   0
	      40p     1   1   0   0     50p     100p
	      50p     0   0   1   0
	      60p     1   0   1   0
	      70p     0   1   1   0
	      80p     1   1   1   0
	      90p     0   0   0   1    100p     200p
	     100p     1   0   0   1
	     110p     0   1   0   1
	     120p     1   1   0   1
	     130p     0   0   1   1
	     140p     1   0   1   1
	     150p     0   1   1   1
	     160p     1   1   1   1    200p     500p
	Bonus 1
	Games awarded.    SW5   SW6
	            0      0     0
	            1      1     0
	            2      0     1
	            3      1     1
	Bonus 2
	Games awarded.    SW7   SW8   SW9
	            0      0     0     0
	            1      1     0     0
	            2      0     1     0
	            3      1     1     0
	            4      0     0     1
	            5      1     0     1
	            6      0     1     1
	            7      1     1     1
musashi
13CR
Thanks I spotted it says mars on the board and have also googled "pcb 84275" and something from a mame forum does go through some aspects but nothing meaningful or no diagrams..
trial and error approach it will be, unless anyone else has that specific board diagram so I can make heads and tails of it cheers
