I have an old Mars ME126 coin mech (untouched since the mid 90s) and I want to update it to take new coins, from what I can tell, I need a fancy machine to do it.
Does anyone here reprogram them to take new coins?
If you don't get any luck on here, I think there's a company called ' e service ' within the industry that does the reprogramming you'd require. If it's for a video game then anybody with the equipment would be ok but if it's for a fruit machine be careful. This is because the smaller operations tend to attach the £2 coin to the £1 coin accept line and for the machines that came out before the £2 coin was released this causes a problem with the float levels as it adds the £2 coin as 2x £1 coin and adds this to float level/hopper level. The bigger companies will program the £2 coin on the the 50p accept line as it should be done thus avoiding the issues of your hoppers going empty when the machine is saying it is not. I only say this as I have a ' casino crazy ' club machine doing exactly this.
Sorry about the waffle but yeah 'e service' if you get no luck.
If you are using the coin mech in a Jamma cab, what credit board is it connected to? It might actually be cheaper to buy a second-hand coin mech already programmed for the newer coins rather than send yours away for re-programming. You can probably also use another model like the ME111 instead.
I think these worked on both the Mars mechs and the coin control ones, as your original is a Mars stick with that. So as previously suggested the me111 updated to new coins would be best as it will fit where your old one came from. NB the only issue to be aware of is whether you coin mech has a front coin reject (non accepted coins come out just below the coin entry through a slot with 'U' shaped piece of metal stopping it from falling on the floor,and you can see the coin) or a bottom coin reject ( where the coin is dropped into a little cube shaped metal box with a flap).
Its the type with the U shaped ring below to catch the coin. Where is the best place to buy coin mechs? I search for mars coin mechs and seem to only have second hand ones on ebay (not sure if they work with new coins) or some vending machine style ones.
