Common Connectors
Purity
The Oracle
17 (100%)
2,999CR
Atari Audio Regulator II
Ordyne said:
Molex Standard .093"
Part numbers for the housings to plug onto the ARII
1x 4 Pin 03-09-2049
2x 6 Pin 03-09-2062
1x 9 Pin 03-09-2092
1x 12 Pin 03-09-2122
Power Brick 3 Pin housing plug (for mains lead) 03-09-1032
Male Pin 02-09-2103 14 - 20 AWG
Female Pin 02-09-1104 14 - 20 AWG
Male Pin 02-09-2118 18 - 22 AWG
Female Pin 02-09-1119 18 - 22 AWG
Please double check before you use this info :)
Plugs for AR2 (if you want to create and extension cable for testing) are:
4 Pin 03-09-1049
6 Pin 03-09-1064
9 Pin 03-09-1091
12 Pin 03-09-1121
Purity2019-01-18 11:35:50
Purity
The Oracle
17 (100%)
2,999CR
Taito Space Invaders
Power PCB
Headers
1-380991-0 - 10 way
350214-1 - 16 way
350220-1 - 12 way
Housing
1-480438-0 - 16 way
1-480287-0 - 12 way
1-480285-0 - 10 way
61314-6 - Crimps (female)
Purity
The Oracle
17 (100%)
2,999CR
Hantarex MTC90/900/900e/9000 and 9110 connectors
2way housing #280590 RS #509-1641 - used for the degaussing coil
4way housing #280591 RS #509-1657 - used for power
6way housing #280592 RS #509-1663 - used for video and yoke
crimper pins #280702-1 RS #668-9381 - used with all above
(Info from Ace)
Purity2019-01-18 14:15:13
