Copy Partitioned Micro SD card
Coops
63CR
Hey,
Can anyone tell me how I can make an exact copy of a partitioned Micro SD card onto another card?
I foolishly just tried dropping the folders onto the SD card and it didn't work
Coops
63CR
I looked at win32 disk image but couldn't find anywhere where it would copy partitions. It has 2 partitions with their own drive letter and also they are in different formats, one is FAT the other is FAT32.
ColinD
6 (86%)
1,367CR
As above.... https://www.osforensics.com/tools/write-usb-images.html
Also you could use any usb image reader / writer as also mentioned such as win32 disk imager.
balenaEtcher is also a nice simple one to use too.
https://www.balena.io/etcher/?ref=etcher_footer
Venom
818CR
Just remember when you make an image and paste to another card you can get issues with size of cards even if they both say they are the same e.g 256GB
I tend to only use same identical cards Sandisks I find the best.
Thx
Coops
63CR
I must be doing something wrong, I tried both win32 and balenaEtcher but it wouldn't copy the partition as a whole, I had to select each folder at a time.
patzik
388CR
When using win32 disk imager you select the first 'drive' and it will copy all partitions in one image. Another tool I like to use is roadkil disk imager.
Coops
63CR
Great, thanks for that I will try it in the morning. I did try another program called diskgenius but I kept getting errors.
Hopefully I have better luck this time.
patzik
388CR
Just to clarify my last post. With win32 disk imager, you select the drive letter of the first partition on the drive you want to image. Personally I like roadkil more, it allows you to image a drive letter bit also show the physical disk number as an option.
