Corroded Q*Bert PCB
Purity
The Oracle
17 (100%)
2,999CR
I've never dealt with a corroded PCB so am looking for some advice on how to tackle it.
I've removed all the components that have been affected by the leakage, and neutralised the board.
But now that I've cleaned up the PCB I'm starting to think I'm going to struggle to solder the components back as there are some tracks that are damaged, and quite a few pads, so want to get some ideas on what I can do.
I've took some pics of both sides of the board:
https://farm9.staticflickr.com/8746/16855200200_cbd8f254e7_o.jpg
https://farm8.staticflickr.com/7610/16855200570_7bc3624728_o.jpg
Purity2015-04-06 19:25:47
smarty
Ready Player One
1,305CR
Out of interest how did you 'Neutralise' the board? I've got a battery damaged board on its way and I need to do the same thing before I think when it arrives.
Your photo of the bottom of the board doesn't look in a too bad state. Have you tried applying new solder to all the socket holes and then removing it to see if it 'tins' the original position.
Worse case you could make kynar wire links from the IC's to the 1st part of circuit that you can solder on to.
Thats a total guess from me as I've never dealt with this kind of issue before.
Cheers.
Purity
The Oracle
17 (100%)
2,999CR
Cheers.
Thanks.
The battery is an alkaline battery, so I used a white distilled vinegar with acetic acid (a mixture of 50% vinegar/ 50% water) to neutralise the alkaline on the PCB
I'm not sure I'm 100% on the process as I've asked people in the past and they didn't want to share the info, but what I did was:
1) Removed the battery and other components that had clearly corroded - gone green, rusty, disintegrated etc
2) Used a soft toothbrush and applied the acetic acid mixture to the affected area only (both sides of the board). I did this twice
3) Left for about 25/30 mins
4) Cleaned the board with tap water on both sides of the PCB. Did this twice. (distilled water is probably better)
5) Repeated the process
6) Left the PCB to dry
7) Brushed off any white powder caused by the alkaline being neustralized
8) Cleaned the PCB with isoproyl alcohol
I don't know if this is 100% but it's what I did. If I'm wrong anywhere then please let me know. Otherwise I hope this helps.
I think I will struggle to apply solder to the pads in the current state. A good suggestion has been made to use some wire wool to help with this.
Yup, I can try and use kynar wire for any breaks if I can. This is what I usually do with broken tracks
Purity2015-04-06 20:31:36
