CPS1 High Score Save?
stevearcade
The Trevor Horn of UKVAC
194CR
Hi Guys,
Is there a way to get CPS1 boards to save high scores, so they'll still be there when I switch my machine off and on again?
My scores are nothing impressive, but I'd like a reference point to know I'm improving. You know, pour yourself a beer and try to beat last nights score
. That kind of thing.
The board in question is a Japanese version of Street Fighter 2 Champion Edition.
Thanks,
trm
2,877CR
Hi. Unfortunately I'm not aware of any CPS1 games which include high score saving. If you think your board may support it then the best bet is to find the DIP settings for it and see if there is an option.
Hacking the game to support score saving would range from tricky to an embuggerance
. You'd need to modify the code and board. The board mod would be to fit a battery-backed up RAM (or maybe an EEPROM) somewhere on the bus and then mod the code so that it wrote the scores to the new address of the battery backup storage. Then you'd have to mod the scoreboard code so that it loaded from the backup storage instead of using default values from the game ROM.
If there is free space in the game ROMs then that'd be a good start and you'd have to find a RAM or unused socket which is on the CPU bus, replace the RAM with a timekeeper type, then write the aforementioned code hacks.
So basically not trivial if it's not already in there and just waiting for a DIP change to enable it. There is a sticky in the top of Tech which lists manual/DIP sites - try Crazy Kong.
I quite fancy doing this for something like Bubble Bobble but I've not (yet) had time to poke at the schematics enough to see if there is some place to fit a timekeeper/battery backed RAM.
ps The above plan is based upon the game executing unencrypted code. If the system uses a non-standard CPU then you'd also have to encrypt your new code appropriately.
stevearcade
194CR
So basically, there's no simple high score save kit I could pick up from somewhere, and pop on the board like with some other PCBs. Oh well, it's worth asking. Thanks for the detailed response trm, much appreciated.
strykr
1,351CR
People put up Hi score save kit requests on KLOV, might be worth doing a search? next time your round we'll have a score comp :)
Stone
47CR
The MAME CPS1 driver mentions an EEPROM in several places - is this just there to save operator settings?
Am I right in saying that phoenixed boards are running unencrypted? (having the battery-ram in the C-board's IC go flat makes the jump table revert to zeroes and the phoenix code roms convert the original jump addresses to the correct one, but is code encrypted on top of the jump protection?)
With any luck the highscore code will have been part of a library given out to all the devs, as on other systems - that would be nice :D
Stone
stevearcade
194CR
Stone
Sorry trm and Stone, you're losing me. I don't know things in as much detail as you
I get the impression from trm, that it's not really possible. I also get the impression from Stone that it is?
My brain hurts
. But thanks for the input
Stone
47CR
Nothing's impossible, but some things are easier than others
Basically trm is saying don't get your hopes up. I'm not fussed either way, I only have a couple of CPS1 games...
Stone
