CPS3 carts
tronbaby
62CR
Hi all,
As I understand, once the battery dies, CPS3 carts can’t be resurrected .
I’ve got a Darksoft solution but I want to make sure the originals I have don’t die.
What can be done to ‘maintain’ them?
tronbaby2021-04-12 23:48:08
thegreathopper
1,253CR
Change the batteries regularly, once every 5 years should be fine but beware you can kill the cart swapping batteries.
I changed a couple successfully and then killed one!
5,332CR
SF3 Second Impact doesn't die. The battery had actually fallen off the PCB in my cart when I got it
It was an oversight by Capcom that, I think, helped with all the decryption many moons ago.
5,660CR
Hopefully an infinikey type solution once the encryption gets cracked.
Anyone know if it's being worked on? Arcade Hacker maybe?
penrhos
747CR
You have to be careful swapping batteries - a helper battery to keep it going while you remove the old one, make sure if yours has the extra wire it doesn't drop off and make sure the new battery is good and soldered in well before removing the helper.
Even then they can die on you randomly after a battery swap.
I've had a 50% success rate with mine. The ones that died I converted to Darksoft multi-carts.
But a SF3 Second impact cart works even if the battery is dead.
penrhos2021-04-13 12:49:58
