Crazy Kong pcb, FIXED!
DKams
2 (75%)
20CR
Hi UKvac members,
I got a crazy kong pcb. Unfortunate it misses all the rom ic's. I haven't got these IC's. Know I'm having the idea to repair, well replace these IC's. I think this will be an expensive or not the most economic smart idea ;).
Know I'm wondering what would you do... fix or not? Or does domeone know a cheap address??
DKams2014-12-10 20:04:06
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
if you have spare ICs then its worth repairing
other wise its better to sell as is
the price for non working PCBs has rocketed and from what I understand Crazy Kong is a licenced game so isn't a bootleg
obcd
3,830CR
You could try to figure out what type of eproms are compatible with the original roms that where on the board. Next you'll need to find those second hand. You might find them cheap like that. Probably there will be other faults with the board which is why they removed the roms.
DKams
2 (75%)
20CR
Thanks guys for your replies... I'm just too enthusiast so I thought these evening, I'll just give it a try :). (After all the good advice... I know, sorry ;-)!)
So this decision just pops up more questions...and searches.
I did some research on a crazy kong board I already have. This uses a complete set of 14 eprom's. The first two are different from the rest.
1 and 2 are: NEC D2716D eproms
3 - 14 are: TMS 2532 JL
After a quick search on the internet I found these eproms: M5L2716K. After comparing the two datasheets I found out that these M5L... have got faster reading capabilities. Does this matter for the arcade pcb?
NEC datasheet: http://www.datasheetarchive.com/dlmain/Datasheets-8/DSA-153017.pdf
M5L datasheet: http://electron-pv.com/PDFs/IC/M5L2716K.pdf
The TMS 2532 JL, I did find them, but a little too expensive... Does someone know, or, maybe has these for a lesser price? For 12 eproms I have to pay ~30 euro excl. shipping.
Thanks,
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
2532 are gonna be a nightmare
not many programmers can program them
but the 2732 with a few modifications can work you would need to jumper wire a few pins to swap them around
and 30 euros are the actual price they go for, I pay around that price aswell for 2532s for the amount you want (£1.75 each)
Ace`
PlanB contributor #1
40 (100%)
4,035CR
iirc TMS2532 are the same as standard 2732.
Nevermind I am thinking of TMS2516 being the same as 2716. Crazy Kong boards may have jumpers to switch between 2532 and 2732 though.
Ace`2014-11-05 22:06:27
DKams
2 (75%)
20CR
So, if I understand correctly:
TMS 2532jl replace them with: 2732
1: Program the 2732 just like every other eeprom.
2: Modify the arcade pcb ic sockets, swap A11 with E.
Pic: https://www.futurlec.com/Memory/2732.gif
That should work. And if I understand it right, the 'issue' with the 2532 is that is hard to program because of voltage needs?
That should do the trick?
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
your almost there
lift the 2 pins I have indicated with >
the jumper them as shown to the board
I THINK THATS RIGHT ........
silverfox07862014-11-05 22:36:03
DKams
2 (75%)
20CR
Thanks a lot, well to investigate further, I found this, will your jumper setting still be ok?
Archived from groups: rec.games.video.arcade.collecting
The 25xx series is almost exclusively Texas Instrument TMS Eproms.
As the story goes, TI developed the TMS-2716 (2K Eprom),
but like the 2708 before it, it needed three voltages sources
to program/use them . This was more complicated and therefore more
expensive.
At roughly the same time, Intel also launched "their" 2716 chip
which was different than the TMS-2716 in that it only needed
a single voltage to program (25v) and a 5V to operate.
The Intel pinout was also a bit different than the TMS pinout.
Akin to the Beta Vs. VHS battle, only one could survive
and Intel proved to be the more popular, and thus, most
other manufacturers produced Intel-like 2716.
Bowing to pressure, TI also produced an Intel-like chip
but could not call it 2716 since they already had a 2716.
So they identified it as the TMS-2516.
And thus was born the 25xx series.
Recap :
TMS-2516 = Intel (and all other) 2716
TMS-2716 != other 2716
TI specific, limited use (..in arcade games anyways..)
Unfortunately, the story doesn't end there...
After the 2K chips came the 4K chips (xx32)
Intel simply used the same pinout as it's 2716
and added an extra addressing pin, thus the 2732.
TI again decided to use a different pinout
and to differentiate itself from the Intel 2732,
it named it the TMS-2532.
So 2532 != 2732
Virtually all 2532 you'll find are TI chips.
Only very few manufacturers other than TI made 2532.
(...I've only ever seen Motorola )
Most everyone again followed Intel's lead to create the 2732.
As far as I know, there is no TI 2732.
(...but TI stopped the madness by adopting the Intel
standard for all chips starting with the TI 2764 )
Also, unlike the TMS-2716, the TMS-2532 WAS pretty popular
and used in several applications (...notably arcade games. )
So it becomes a little tricky to know which 4K chips to use
in which game. PacMan for instance, uses 2532's, Williams
game Roms (Joust, Robotron, etc..) use "mostly" 2732,
but the boards can be jumpered to accept 2532.
So to answer your question, NO, 2732 and 2532 are NOT programmed
the same way and are not interchangeable without some board modifications.
Virtually ALL eprom burners will do 2732,
but some of the cheaper ones will not do 2532.
As for programming voltages, all early Eproms need 25V.
Chips ending with an "A" (like 2732A or TMS-2532A )
need 21V. The 12.5V is only used in "newer" Eproms (circa late 80's),
typically CMOS chips, like 27c010, etc...
(a good eprom burner with decent software will know which
parameters to use for each chip )
So as you can see, there are a number of factors to consider.
Hope this helps.
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
yeah It will be
I read the TMS story before about the rivaley etc
as long as you get the pins in the right place then AM2732 or AM2732A will work fine silverfox07862014-11-05 22:54:04
DKams
2 (75%)
20CR
Well...there's a weird thing here, I'm still searching the internet, and I just found this on ebay:
http://www.ebay.com/itm/Crazy-Kong-Part-I-Donkey-Kong-pcb-non-jamma-/191376967821?pt=FR_Jeux_Vid%C3%A9o&hash=item2c8ef4c88d
I've got exactly the same pcb as this one! But the seller sells it as a crazy kong part 1 pcb. If I look at the pictures, I can't make out which eproms on this board it uses...maybe these are other ones? Could you see it?
Thanks for your help by the way!
favouredson
Super Star
1,260CR
I have a Falcon FCK-00 PCB here and it has 2732s rather than 2532s.
There are solder pad jumpers on the underside which you can use to select your preference.
Regarding using 2532s/2732s, if your programmer doesn't work with 2532s it is far easier (less fiddly and much neater too) to make an adaptor to program them as 2732s rather than hack every single ROM.
As there are 12 on this PCB alone it will save a hell of a lot of hassle.
DKams
2 (75%)
20CR
@favouredson, I didn't saw your post before the weekend. I didn't set my mail correctly. Thanks for your reply.
So I can order the 2732s for sure I think. I did a match on the solder pads on both boards I have (see the photo's)
1: The blue fck-00 up for repair pcb:
2: The green I have with 2532s pcb:
So, I'm sure I can order the 2732 eproms. But just for the double check, could you check this?
The other question: the first 2 (11a & 11c (eprom 1 and 2) ) are 2716d eproms right?
Thanks in advance!
favouredson
Super Star
1,260CR
On my PCB the two pads on the bottom of your pic are closed and the top two are open.
There are two sets of pads on the top row, one is for the program code (ROMs 7-12) and the other for the sound code (ROMs 13+14) and both are soldered the same way.
The pads for the graphics code (ROMs 3-6) are soldered the other way round; the top pads are closed and the bottom pads are open.
To avoid confusion (hopefully) the 'bottom' pads are the ones closest to the side mounted edge connector.
ROMs 1+2 are 2716s so any variant will do.
Hope that is clear enough.
