Credit button through lock
Shinydaz
814CR
I wanted a credit button adding to my newly acquired Operation wolf cab. It would be easy enough to drill/file the coin door lock hole and pop a full size button through there, but I don't like hacking stuff up to much. I decided to use an old coin door lock which I don't have the key for. I took the barrel out and simply fitted a small button through the hole. The button has microswitches built in, so I simply put some spade connectors on the connections and moved them across off the coin mech. Not a huge job but it works well and I haven't destroyed anything.
Venom
819CR
Looks very neat and great idea.
I have an old woody and the coin return pushes the metal mechanism to the right when you press the coin reject button.
So I screwed a microswitch inside the so when you press coin return it hits will then knock the switch and give you a credit !
Flinnster
The Dino King
29 (100%)
2,566CR
That's a very neat job if the door stays closed without a lock in place!
I'm still working on my freeplay mini pcb, that will prevent any cab mods being needed. It allows you to credit up by holding down an existing control panel button like 'start' [:)]
Mr20to5
1,366CR
This is the first mod I ever did and have repeated on many a cab, since being told about it by James RGP at the opening night of the original arcade club. However that is a very nice round button, where did you get it from?
Shinydaz
814CR
I cant remember where I got these. If you search for arcade service button either alexepress or ebay you'll find similar.
You could put the latch back on the back and leave it loose enough to twist it around by hand at the front but you might need to double nut it to stop it coming loose.
