I'm helping acidburn out with testing / fixing his Defender board set so thought the following quick tests summary would be helpful for anyone else who's new to Defender and trying to test their boards
1. You only need the CPU and ROM boards to start
You won't hear the distinctive 'Bing' noise when the power is turned on as the sound board obviously isn't connected but at least you can see what is going on
2. Follow the red lights
When I first got my board set I couldn't understand what the manual said about the ROM board lights so here's a video (of acidburn's ROM board with my cocktail CPU) doing a correct boot sequence
Power on = 4 lights all lit, then off about 2 seconds later
Boot up = All lights off for about 20/25 seconds
[You will get what is generally called the 'rug pattern' on your screen at this point. For Defender 101 this had me totally confused but it is basically the video memory being filled with data while the boards load and you get a left to right filling of the screen with random data while it does so. Looks a bit like a Persian Rug as it does so, so I guess that's why it's called the rug pattern but you can see the RAM memory fill up with data while it's doing this - so if it crashes half way or keeps resetting when it get's to a certain point, then you know to go and check your (normally flaky) 4116 RAM to see if it stops at a different point if you swap the chips around)
Successful boot = All 4 lights flash twice then off
3. Many boards have their sync inverted for JAMMA or similar
Here's acidburn's ROM _and_ acidburn's CPU board correctly booting, but you'll notice the screen is out of sync. This is often because the CPU boards have the sync. fix mod done to them (see my or any other favourite Williams site) and have it switched around.
Here's the details from Robotron's site for reference
You can add a switch to fix this, or solder back the jumper if you want a more permanent solution and here's a picture of acidburn's CPU showing the jumper cut on his
Here it is highlighted for reference
and if you do want to change it back just solder a bit of wire (or the leg of a capacitor if you don't have any wire, or a switch if you want to have it changeable) between the two blue circles in the image like the blue line
4. Final Test
For VirtVic who was over at ours yesterday picking up his Subelectro #8 and the Defender cocktail was stuck in CMOS mode - if you are having problems stuck in CMOS settings, just disconnect the CPU middle connector as I have done here
Next time Vic!
Hope that helps a few others one day
Judder
Judder2019-04-05 23:59:21
4. Final Test
Next time Vic!
Judder
