Hi everyone
I have a Williams Defender CPU board which has developed the beloved RAM error on boot
After changing all of the RAM I still get the same error, and it is with RAM 38 according to the RAM test (38 is the bottom right of the 24 RAM chips on a later two decoder board, literally ROM 3 position 8)
What is strange however is if I remove any RAM chip in 35 -> 38 and re-run the test, it always says RAM 38 is faulty
Removing any other RAM (I tried 18, 28 and 34) correctly identifies that RAM as being the faulty RAM
Therefore I'm wondering if this could be an address / chip select chip causing the issue instead which just fails to select that bank?
Checking the schematics if appears the RAM chips are selected in banks of 4 and shows 3Z, 3Y, 3X and 3Z (38, 37, 36, 35) as a bank together
Not quite sure how these are selected and by what chip though (there are some 7447 flip flops near the top of the banks which at a guess could be involved)??
It looks like the RAMs are selected using the 8 74165, 8-bit shift registers at 1O, 1P, 2O, 2P, 3O, 3P, 4O, 4P and 3Z is selected by the one at 40, pin 14 or 4P, pin 13?
Thoughts much appreciated!
Judder2015-08-24 16:22:42
