Defender Power Supply
RolyRetro
278CR
I'm attempting to recondition a power supply from a Streets Defender, and trying to understand if the orange gunk that appears to have dripped from it is normal. The gunk is rock solid and appears to have dripped out of the centre of the unit, staining the edges of the case around it.
Is this normal, and should I just clean around it? Does it have a function? Or does it suggest the unit is shot?
philmurr
48 (100%)
2,378CR
Likely to be epoxy used in manufacture as insulation
I wouldn't worry about it, power the transformer up with nothing connected to the secondary and as long as it doesn't smoke you should be fine. Measure the output voltages just to be sure.
