Defender Question
Macro
2,010CR
Looking at a defender set and not totally understanding the problem.
turn it on (or reset) - goes through rug test, comes up with 'all systems operational'
but then it jumps into the settings screen
advance steps through the settings, select function 28 and then advance, and it goes away, just to reappear a later, back in the same screen at function 1
high score reset does not appear to do anything, but appears to be wired correctly
any ideas on what I should check ?
first defender I've tried to fix, just annoying since it says 'all OK' but then won't play anyway!!
Baiterhater
73CR
I had this a while back but I can't remember the exact IC as I've been very busy with a work project ever since. Basically the memory protect interlock switch at the coin door was always grounded due to a shorted ic, I'm sure it was in the Cmos circuit somewhere. Phil Murry helped me find the issue.
I have a look at the schematics tomorrow see if it jogs my memory
just
cliff_poole
1,069CR
You're not the only one struggling with memory. I know I have seen this but it was probably over ten years ago and annoyingly, I wasn't documenting my fixes back then. Might have been either a faulty bookkeeping RAM chip or the PIA for the bookkeeping switches.
Good call with the coin door interlock too. I actually had that last year with my Pinbot. I'd just fitted an NVRAM chip, it wouldn't save settings and start play. After hours checking everything multiple times, I found one of the wires to the coin door interlock was just wrapped around.
philmurr
48 (100%)
2,374CR
If it doesn't let you change the settings as you step through the menu then it's likely to be the door write protect switch or associated circuitry
If you can make changes but then it won't let you save then I'd think faulty CMOS RAM which is kicking you back when it fails the checksum
Baiterhater
73CR
Ok from my sketchy memory pin 20 of the 5101 was being pulled low constantly, I actually first thought it was the cherry switch on the interlock but like a donut I was testing it whilst it was still connected.
I think it was the 7404 at 5b the output pin 4 being shorted to ground.
I’d also be looking at 4j and 6h
Just
Edited to say the expert beat me to it ?? and if it wasn’t for Phil mine would probably still be stuck in book keeping
Baiterhater2022-05-05 08:37:37
chadsarcade
Lord of Vectors (tm)
443CR
Usually down to CMOS failure (particularly if you see question marks in the settings screen), but I've also seen bad 4071s and trace the write inhibit back as detailed above.
I have FRAM replacements for the 5101 CMOS chips.
Chad
