Defender ROM reading/version questions?
Judder
1,009CR
Hi again everyone
I'm braving away on my own trying to fix my Defender boards and am making slow, but progress none the less.
I can now read in the ROM chips I have with the Willem device I bought, but I seem to either have a different version of the ROMs from those available for Mame, or there is something afoot.
What is even weirder, is ROM8 which contains all the text for the game 'WILLIAMS', 'TILT' etc. shows all the text in my ROM dump just fine, it's just none of the code before _or_ after matches the hex values of the other dumps.
Here's some Hex screen shots of Red versus White versus Green versus My dumps.
Any thoughts as to what might cause this and/or if is correct?
Defender ROM 8 White
000005e0 = 54 48 2f 59 4f 55 2f 01 08 c6
Defender ROM 8 Red
000005e0 = 4f 55 2f 01 08 c6 97 01 08 c6
Defender ROM 8 Green
Defender ROM 8 Alex
000005e0 = 4f 55 2f 01 08 46 17 01 08 46
Defender ROM 8 Red
Defender ROM 8 Alex (looks similar to Red but is different)
Judder
1,009CR
Answering my own question, it seems to be that it did a slightly dodgy read with the Willem
Re-reading the chip again I get
000005e0 = 4f 55 2f 01 08 c6 97 01 08 c6 af 01 08 c6 b7 03
which matches the Red ROM set readings
Wonder why the chip was returning wrong results for values over hex 80?
Values returned where 46 instead of c6 and 17 instead of 97, all 80 out from each other.
Maybe the speed of reading (*new device still learning so amazed it works this far...)??
P-Man
International man of mystery
1,273CR
Its a simple case of a bad read, bad contact between the rom and the reader.. you'll get the contents appearing all over the shop.
red is most common romset, and best to play on at least.
Judder
1,009CR
Thanks Andy - I'll try them all again and see what I get
Also - as the chip legs are so fragile as they are _old_ I'm mounting them on 24 pin 0,6" IC Socket Connector DILs and then plugging these in which shouldn't effect the read speed, just means that when I take them in and out I'm not bending the legs on the chips
Also IC Socket Connectors are much cheaper and easier to find than replacement chips
