Since I built my scratch Robotron last year i've wanted to build another scratch build.I did want to build a Tron but what with the shroud,plastics etc...that idea went out of the window quickly as trying to source these items would have been a pain and probably very expensive as well....
So I decided to build a Defender as this is another game I played to death as a kid and have very happy memories of playing it in the arcades of Leeds....
I know a few people who have original cabs so getting measurements etc...wasn't going to be a problem,I also have a spare Jrok board....
A forum member I no had many parts from a Defender cab he trashed (the actual cab itself was too far gone to attempt any kind of decent resto he said so he stripped all the salvagable parts and put them to one side for me for when I were ready to start my project).....
I did the same as my Robotron regarding the shape of the sides...I got a piece of hardboard and just basically pressed it up against the original cab and drew around the shape and then cut it out at work with a jigsaw...
I am using the same material as I did for my Robotron which is 18mm Birch Ply.A great material to use.....
The two sides cut out...
The rest of the panels cut out...
This piece has the desired angle on each edge....
The bottom back piece and top back piece have rebates on them to accomodate the rear door...
Start to Build...I have used the same 'L' shaped brackets as well which will not really be seen once the cab is finished as i'm having the whole cab sprayed black inside as well....
I have set in the bottom of the cab to accomodate the casters i'm using (the same as my Robotron again)...
For those eagle eyed ppl you may have noticed that I haven't cut out a hole on the underside of the coin door area to accomodate the small on/off switch...I were gonna do this but tbh i'm just gonna use the mains plug to turn the cab on/off as it won't be at the back of the cab once its finished and insitu...
Both sides on and a bit of wood filler applied...I also pinned the sides etc...as well for extra strength...
The groove cut out for the T-moulding...
Thats all for the moment...I'll keep updating this thread as work progresses...
Russ...
Russ J2016-03-02 19:28:20
Russ...
