Defender speaker
bonehead
I'll get pix tonight
50 (100%)
1,729CR
I know I asked his a long time ago but could someone tell me which ohm speaker should be in an upright defender?
Mine is clearly the wrong size and possibly the wrong ohm and wattage. I'm keen to put it right and back to original.
bonehead
50 (100%)
1,729CR
That's brilliant thanks for the link.
So would either of then2 ohm version give the same quality sound or is one better than the other?
bonehead
50 (100%)
1,729CR
Ok just done some googling and will stick with the correct size unless anyone thinks different. I'm using a j-rock board so I guess it was designed to cope with both.
Battlezone
410CR
Steve,
I'd definitely go with the 4Ohm 6" you'll get double the watts out of it (audio amp and speaker wattage
allowing). It's a shame they didn't spec the max speaker wattage too.
BTW I had a couple of goes at "killing-the-vile-pink-humanoids" on defender during your last meet and it sounded ok to me.
