Defender/Stargate - working :)
Judder
1,009CR
Thought I'd share a little bit of my joy that after 6 months of on and off plinking (and learning!) with my Williams Defender I've finally got it to work with a Stargate set - hoorah!!!
After replacing all the memory on the CPU board with New (old stock) unused memory I was still getting a 1-3-1 error which I believe is the first memory chip to be tested complaining of not working correctly.
So off I went with a multi-meter to test voltages and it appears that it was actually the wiring to the power plug connecting to the CPU board being loose as prodding the top of the plug with the multi-meter probes, and then booting up resulted in a 0 (a pass for those who read this later) from the ROM board and a working game as below :)))))
I currently have the Defender interface board connected so Fire and Thrust aren't working - can any advise if replacing with a Stargate interface board will resolve this or do I need to rewire the control panel?
Happy days and I can go and do my day job now :)
Judder
  • Like
Reactions: trm
tb lilley
5 Star
1,686CR
Congrats.
Depends which interface board you have. Some are capable of running both Defender and Stargate. Presumably you have one of those type. So you should be good to go. Check you have Fire and Thrust controls properly grounded. My bet is that you've a dodgy ground on Thrust (Thrust, then Fire, are the last in the ground daisy chain).
andyman
1,059CR
Woooooooohoooooooo. About bloody time too
C8783 is the board that will run both, 8353 & 8573 are defender only
Judder
1,009CR
Thanks TB and Thanks Andy - much appreciated all of the advice on this 'journey' and definitely learned a lot on the way!!!!!
TB - yes that makes total sense as I rebuilt the Control Panel myself so will check the connections to the Thrust button and update whether that fixes it.
Andy - thanks again for all your help and the interface board has the serial sticker over the board ID, but it is ending in a ..14-X1 and has 3 chips in the middle positioned vertically with two horizontally underneath.
I think from Dave's site that means it is a C8783
"Identifiable by 5772-09614-?? (??=Revision) etched on the PCB"
Now does anyone have access to a stencil set so I can fix the ugly paintwork by the coin slot mechanism...
