degaus problem/questions
handbakedarcade
264CR
Hi guys
I have a kortek KTM-F monitor and it has a degaussing issue. Firstly, it never had a degaus coil on it until just now when I bought one over as a spare. However, it occured to me whether the degas coil has to match the chassis to ensure resistances are correct etc, or is that not a concern?
with the coil plugged in, when first turned on you do see the 'jolt' effect in the 4 corners before the crt warms up and shows the image. However, the bottom left of the screen is still slightly purple, as it was before. I have tried leaving it and power cycling it with half hour intervals, with no luck. it is the opposite side to the speaker thats in the cocktail cab.
I have read that the PTC may be a problem. Can anyone tell me how to test one please? also where replacements can be found nowadays? supposedly a PTH451c06 according to this manual:
http://thydzik.com/mamecab/KORTEK%20Color%20Raster%20Display%20Monitor%20-%20Instruction%20Manual.pdf
any help appreciated.
cheers, tom.
andrewsm
485CR
The deguass coil is simply a coil of heavy duty wire. Resistance is low. There is no real matching issues as when the power is applied and sudden surge of current is fed though it which makes a magnetic field and removes any stray magnetism on the mask in the tube. The fact you get a disturbance means its working. If there is still problems it sounds like something else is cause a magnetic field near the tube. The other thing is maybe the tube has suffered a bad knock. Might need a manual deguass on it.
