This is another one of those things that will get harder to buy with decline of CRT the demand drops, when i started buying arcade machines most people still had crt tv, i was just starting to change over to LCD TV and was happy to see these old bad breaking TV's gone only to have to start humping Arcade Monitors around and repairing them again, so annoying as i used to have piles of old TV boards i could of used parts off for them.
never even gave it a thought about the future when most CRT are gone where are u going to get Loptx for these monitors, should of planned ahead and bought loads of spares and at time degaussing wand was available from any TV spares supplier like Wiltsgrove in birmingham which i used regular for TV repairs and got replacement lopt for Op Wolf Hatarex Monitor in 2002. All places like rs, cpc etc sold them now they dont the stuff or places have gone as there business has gone with decline with repairs as eveything so cheap now no point fixing most and change so fast useless after few years
Now most of this stuff gone the only option seems to be cheap chinese goods and the other year when i needed a new lopt for this original sanwa turbo outrun monitor i realised just how difficult it is to get them now
Maybe someone should look at making some deguass wands. All they are is a coil of wire and switch set in apoxy resin isnt it.
Tv/monitor have built in degauss on tube with auto thermistor at switch on, trouble is most monitors are 110v but arent some degauss side 240v? Or was it other way around? Cant remember now, but i'm thinking if you had old crt tv, the degauss circuit are all 240v so if you already have the coil on back of tube thats well made to high standards, if you took that off tube, get strong cardboard tube and put that inside folded up, would you need to set that inside with resin or not? Or would it be goood enough as its all insulated already, smaller tube TV would be best as coil is smaller, then connect to a momentary switch and connect to 240v mains lead, which is basically all the one i bought is, switch is in the end plastic cap where mains lead comes out, which packed up after short time so i put rocker switch on it. If u wanted you could use the thermistor connected up so its auto like manual button on monitors and cuts out after few seconds
Would be far better quality than ones bought
Only issue is getting cheap crt tv now, local tips must still get some times, wish i could still get bits from there
Whats peoples thoughts on it?
