Desoldering tool
galaxian68
5CR
Just looking some advice, in the past I fixed a few simple faults on boards and had the luxury of a Weller desoldering station in work, but that was 20 years a go and have been trying to use a generic desolder pump, but it tends to bounce around and I'm worried about damaging board tracks. I can't really justify a fancy desoldering station at the minute, but has anyone used the Engineer SS-02 desoldering pump?
Thanks,
Colin
Chihiro
1,008CR
If its a good as their plies then I'm sure its great.
I own 4 of stripped screw (PZ series) & the micro needle nose pliers all excellent & a cut above anything sold here.
I also have some Vessel & Anex JPN made tools.
Funhouse71
1,082CR
+1 on the Engineer SS-02 de-soldering pump the nozzle is silicone so doesn't damage the board and creates a better seal around the pins to be de-soldered. You can buy spare official Engineer silicone tube which you can cut down to size.
5,324CR
Can you actually clear the solder on boards with power planes using a suction pump?
I end up with a Hakko desoldering gun on one side of the board, a soldering iron on the other and considerable frustration on stuff like Konami boards.
Chihiro
1,008CR
I use a T9 style soldering iron that is basically a copy of Hako even has a blue & yellow handle I got very cheap like £30 some years back before the big YT channels reviewed it & the the price went $$$ the case looks like a Maplin project case though.
I've always fancied a TS101 for a portable unit which is also direct tip 10 seconds heat up.
Funhouse71
1,082CR
I had a Hakko once I think it was the older model of the FR-301 which had an inherent design fault whereby the solder fragments would get sucked into the windings of the pump motor and short the motor out. I remember paying about £300 quid and it only lasted a couple of months!
qjuk
51 (98%)
2,072CR
I purchased the Engineer SS-02 desoldering pump in the last week based on the feedback here.
OMG, what a decent piece of quality kit this is :cool: (y), It‘s in a different league compared to my 2 old hand pumps (a plastic and metal one). It sucks out old solder so cleanly, removing old components is a doddle.
LawmanAUT
79CR
5,409CR
Used Solder Suckers all the time for TV, Video Repairs but when I started working on arcade pcbs and double or multilayered pcbs I got cheap Desolder station and never used manual solder sucker since for anything
galaxian68
5CR
Mine is going to be Christmans gift from my partners Dad, so when I open it I have to pretend it's a surpise. Will probably have to desolder something to show him what it actually is lol.
galaxian68
5CR
Used a Weller desoldering station in work 25+ years ago, great piece of kit, sometimes the components just fell out when you desoldered the last pin.
