Does Space Invaders (Midway) need -5V?
Judder
1,009CR
That's an excellent reply Simon - many thanks and totally makes sense!
Finally some correct information for Google to pick-up and relay to others trying to work out such stuff
Equites - thanks for the offer, that's very kind
I've ordered 24 x KR580VM80A, a Russian clone of the Intel 8080A, from the Ukraine for a very reasonable amount (about £1 each) to try out replacing the CPU as there is an interesting comparison 8080A chips and clones here which I referenced
Will report back how I get on and thanks again
Judder
1,009CR
Simon Cornwell said:
but this does look like the 8080 simply isn't running for some reason.
So I switched out the 8080A CPU with a replacement sourced from eBay, removed all of the existing ROMs and plugged in just the 2532 burnt test ROM (2732 image burned to a 2532) and - Voila! - life from the board and a successful memory test.
I've moved the testing to the Space Invaders Deluxe boardset I have as it's easier with the reset circuit there and recorded a quick video of the whole process so that anyone looking to debug this stuff in the future has a good reference going forwards.
Learnings:
If you get display output, then it doesn't necessarily mean that the CPU is working correctly!
Thanks again to everyone for their help
