Donkey Kong
Rasputin
71CR
I bought a donkey kong on Monday, all working fine. It has a donkey kong junior 2 stack boardset modded by Mike at mikesarcade with the double donkey kong kit to allow dk and dkjr to be played aswell as highscore save etc.
So, yesterday I experienced colour issues and was getting many people suggesting eprom at 3N on the video pcb, try taking it out and reseating it.
Problem is this morning when I went to do this I noticed its not a 2716 it should be but a modded rom with wires...
I took the 2 stack boardset out to see if any wires may have come loose etc
But it all looks good to me.
Needless to say I didn't want to mess any further.
Any ideas before i have to make a decision and see if I have to send off the 2 stack back to the U.S to mikesarcade for repair?
Thanks!
TheDaddy
14 (93%)
7,230CR
Its hard , Make sure your voltages are correct and check chips are seated correctly.
Next step is repair or return i suppose. Cost a bit back and forth to USA though i assume.
Dave.
Rasputin
71CR
JC_R4CER
126CR
I've had one of these boardsets before and there will be enough slack to remove and re-seat the 3N eprom. Is there someone locally who could help with this if you're unsure about doing it?
Rasputin
71CR
I'm fine with it just so long as the wire is long enough I can unseat the eprom and reseat it.
But I think it may be the jumper wire attached to the pin... may not me 100% soldered on properly.
Transatlantic travel probably didn't help.
