Elation to devastation
Grandiloquence
103CR
Hi all, managed to lash up my Supergun to test my recently acquired Dolphin Blue Atomiswave setup.
Everything sprang to life and the game loaded. I was really chuffed.
Until it hit the title screen and it did this:
It only happens on the titles, the game portion seems spot on. Any ideas before I break down and weep uncontrollably?
Monstermug
1,807CR
isn't it supposed to ripple like water rather than shatter into pieces like that? Never really worked on atomiswave hardware before but instinct tells me it could be either a bad rom image?
Monstermug
1,807CR
Yes like a bad program file. Unless that effect is hardware rendered which would usually mean it should have a more global effect which you said it doesn't. Could also be talking a load of rubbish. Like I said i've never had to work on atomiswave before. Got one with a faulty sound which I need to crack open but that's in the pipeline. Also there are a lot of fake dolphin blue carts out there. Check if yours is original.
Grandiloquence
103CR
Thanks for the reply. It's an original with the proper Sammy PCB and chips etc. Could the motherboard be the problem? I'll see if I can get a loaner or something to test it out.
Monstermug
1,807CR
Most fake cars look really close to the original. Have to open them up to find or sometimes the serial numbers can be a good giveaway. Yes try different motherboard if its same problem, then it has to be the cart.
Grandiloquence
103CR
Right. I reckon this might be an overheating issue. The glitching only occurs after the system has been running for a few minutes and gets gradually worse the longer it runs.
I cracked open the Atomiswave and had a look at the state of the insides.
The cooling pads have wept silicon oil over the two chips they are attached to so I reckon I will clean up the oil and remove/replace the thermal pads. I read somewhere that when they reach this stage it means the effectiveness of them has been reduced.
Hopefully this will sort out the artifacting issue! I will update this with my findings later.
