Electrocoin Xenon manual? How to get to the marquee artwork and behind the glass
Diewrecked
14CR
Hi all
I'm currently working on a few Electrocoin Xenon cabs. It's much easier to access the pots for the Hantarex screens as they're presented at the back of the game board tray. However I can't fathom how to get the glass out to clean behind it, nor how to get to the marquee artwork to replace it. I've got the original manuals that came with them but the Unigame manual just goes over the edge connector pinouts etc, there's nothing about the actual cab construction. I have all the keys so can open up whatever I need. I found some wingnuts under the speakers which I removed but that didn't help. There are locks top and bottom of the marquee but I don't see what they're supposed to open.
Appreciate any insight you guys can offer! Many thanks.
Flyback2021
35 (100%)
1,831CR
Hi mate
Use top lock above Marquee to hinge retainer back and then you can pull up.
The glass can slide up through the routed out space which it goes into (can see the slot through marquee holder)
I use glass suckers to lift glass up through slot as safest but you can use the metal glass retainer at bottom of glass and lift with friction.
Hope this helps
CoS72
186CR
Hi,
I have not been able to find a manual for these - To remove the monitor glass you open the lock underneath the marquee and that allows the glass to slide up to clear the speaker mounting. You can then lower it and remove. The marquee is the very top lock - the bracket is hinged so then moves away to release the marquee. If you haven't got the keys you can remove the top hinged bracket held onto the cab with 4 button head screws and then you can access both locks and remove.
Diewrecked
14CR
Hi @Flyback2021 @CoS72 TYSM for coming back so quickly, apols for late response. This is EXACTLY what I was after :) I've got the marquee open and I've got the glass out. I'm delighted to get behind the glass as there were really distracting cobwebs all across the screens I wanted to clean out.
I have power issues with some of the others, I'll raise a separate post for that.
Thanks again you guys :)
