Electrocoin - Xenon / Neo Geo 4 / 6 slot /Goliath Restoration and Projects
Flyback2021
35 (100%)
1,880CR
Glad this is done , luckily on works time as finished a job a day early so was being paid ! Nothing salvageable on this apart from internal hinges and locating clip to pull in when fit.Those buttons were so seized they got drilled out.
Did another while in the swing of it, not quite as bad as previous.
View attachment 31929 .
These spare panels have been altered through some blanking out and welding. The threads for the joysticks were tac welded so very strong and provide a nice clean control panel. These will be wired up with some spare xenon looms and can be interchangeable on the cabinet.
04459739-00D2-429F-9B94-7496E0673FFF.jpeg5A04C2A1-B845-4F02-9B12-09509317E771.jpegAF12C871-DEBC-412F-B17B-3FB4623991EB.jpegA8E4AFDD-201E-44B4-A40B-09EB15F8D8AD.jpeg95B03063-BE8E-4E27-9D89-82ED74E9D2FB.jpegAA1C2AB1-F5A4-497C-B722-38B05E2D30D5.jpeg
Flyback2021
35 (100%)
1,880CR
Loads of bits on the go, done all the zinc oxide and first coat on 3 panels .
Also brought a blackening solution (3 part ) to turn a load of button screws and a few smaller metal panels back to black (and look like new !)
Flyback2021
35 (100%)
1,880CR
Slightly early in the finishing phase - red oxide and one spray so far.
These will have overlays added. The Joystick threaded bar was tack welded onto panel .
Both spare panels ( see earlier configuration - one from
Outside xenon) can be interchanged with xenon cabinet.80D38BF4-4786-4261-8190-92178D32853A.jpegF8B6C67E-8901-4FE4-9814-E4F016AAC51D.jpeg420840A0-EE70-4295-A907-A59A028339A2.jpegEBCE7745-6322-4F09-A50B-B3E1922E2B26.jpeg
_Matt_
889CR
Great work on these control panels Ant. I remember the ones that I've done over the years took way longer than expected getting rust off and filling in and redrilling holes. It's very satisfying when you see it all finished.
Flyback2021
35 (100%)
1,880CR
Dont tell him that he is making us all look bad ! Lol.
On a side note i did restore power to my cab tonight why i was waiting for the boiler to stay lit so i could have a bath ! Sodding thing.
Dave.
Great news ! Power restored to cabinet and a bath !
Will be needing a Flagon of your special
Reserve home brew Dave to smash against the side
Of the Midi cabinet when completed !
Flyback2021
35 (100%)
1,880CR
Cheers Matt ! They turned out well and nice to be on the finishing phase with them finally.
TheDaddy
14 (93%)
7,023CR
I have nanaged to source the C02 today that coming wednesday. Should be drinking by Saturday ! Well if tubes good.
Wont be fit for much Sunday ! Lol
Dave.
Flyback2021
35 (100%)
1,880CR
Sometimes missing on xenon’s .
These are used to lock the control panel into wing of cabinet, adds strength to cabinet and keeps the control panel pulled in.
Had to make a few of these so thought I would share in case anyone else needs.
- M6 30mm button screw
- washer
- 10mm collar (aluminum but could be any sort of tubing.
Flyback2021
35 (100%)
1,880CR
For future uses !
All reconditioned and gone through any rust removal and then blackening process ( 3 step - alkaline - rinse - blacking solution - rinse
- dewatering oil) sounds a lot of work but isn’t . Total process leas
Than 40 minutes.
Well worth doing especially if a large quantity.
Use these all the time and costly to buy especially in a handful of each.
Helped 3 members and counting with these already!
Button screws on Xenon - can vary
M6 button screws
10, 18,25,30mm
Neo Geo Electrocoin MVS
similar but 10mm not used
Flyback2021
35 (100%)
1,880CR
Limited time to work on the projects currently but did some reassembly on the Neo Geo 4 slot .Monitor cleaned , chassis put back in ( thanks @gunblade ) picture is beautiful . He also fully serviced Hantarex power supply. Next up joysticks and button clean.
Marquee bulb had gone but there were two unused behind the ballast.
F8W cool white 30cm length.
0D4B39F6-6EE8-420E-8C2D-F606941F702A.jpeg80355310-0DC4-4BE2-AD55-7F1F6055DCD3.jpeg44077EC0-DC19-4F65-8626-C532B53EB207.jpeg
