Electrohome G07 sync/power issues
RGP
Meeter & Greeter
2,039CR
I have a G07-CBO with a problem i've not encountered yet (i've plenty to encounter still
I initially thought this was a sync-curl issue as i've seen it plenty of times on G07's and fixed it by removing C301, putting C303 into C301 and putting a 10-22uf/25v cap into C303 as per the various G07 notes found on t'internet.
While this did mostly correct the issue on this chassis, what I see is when swapping from a full screen to a dark screen and back the curl is there and then straightens itself over a 1.5 second period.
Knowing that horizontal sync issues and "blooming" can be related to power supply from plenty of Hantarex 9000's, I checked the B+, it was initially at 116v, reset to 120v problem is still there.
B+ on a G07 is at the far (CRT end) of the sidecar resistor on the left of the chassis which is in parallel to the main regulator transistor.
At the B+ end I now see 120v, swapping screens on my test rig has no variance other than an occasional 0.1v +/- shift so i'm not concerned too much, however, on the schematic there's a marking for the other end of that resistor which says I should have 145v - I have 168! On changing screens, the 168 varies itself during the smoothing and resets to 168 or thereabouts.
Can I assume that if there's a marking on a schematic like this then I should attempt to correct that voltage reading, looking at it, either the main filter cap is at fault or the regulator on the side, not much else before that test point.
My input voltage to the chassis is 125v which is within the operating range.
Anyone any suggestions?
