Eprom programmer help - Minipro TL866CS
tronads
455CR
I have bought myself a new eprom programmer, the Minipro TL866CS due to mine no longer working thanks to no parrallel port anymore and windows 10. Went for one I have seen people on here say they had success with.
Struggling to program with it though.
My original plan was to use the five TMM27128D-20 eproms on my faulty 1942 board to flash them to rev B and replace the 5 on my good 1942 board (which is rev A).
However, in doing so, I think I have potentially found the fault on the duff 1942.
I grabbed rom 03 and read it, and find it does not rom ident, and on inspection in pspad, i found that some bytes matched and were in consistent locations, but every other byte was similar but not identical. I tracked this down to a stuck high bit 5 on the data bus.
I cleaned the pins and re-read, and obtained the same readings. I then read rom 5, which DID rom ident and matched the mame version, so reading is fine.
So, I then proceeded to erase the 03 rom, and got it to pass the blank check, and read in as all FF's. Next step was to program it with the mame rom, but I cannot get it to go past the first byte, which is F3 (this has bit 5 high).
I am using the software that comes with the device, MiniPro v6.10, but on flashing, I get the following error : "ERROR! Address :0x000000 Buffer Data F3 Verify FB"
After I do this, I can read the chip and its all FF's apart from the first byte with is F3.
Can anyone who has used this device on this type of eprom advise me what settings they used as I have no idea about the likes of PULS delay.
tronads
455CR
Im about to throw this fkn thing out of the window....no matter what I try, it will read fine, but will not program even the first byte of any chips. I have wiped rom 5 which read in perfectly, to try and rule out a duff eprom, but this one wont write either, so now im stuck with it at all FF's.
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
you need to disable check ID
just use the ST 27128 chip which is same
select 21V as the programming voltage
chip to be attached to programmer with pin1 at the upper most of the programmer near teh lock handle
the TL866CS is one of my fav programmers so im sure its just you and that it will be fine
andrewsm
485CR
I had similar problems. I have a stack of eproms and found that some just dont program though Im sure they are OK. I cant get it to do 2716 either despite it supporting them. I find its sensitive to makes of eproms so make sure thats set correct. Also I have a sneaky feeling its needs more juice to program so the 5V usb just wont drive the program voltage at times. Was going to open it up nd tack an external supply in but not got round to it.
tronads
455CR
Ive stuck it on a split lead giving it an extra 2A current, which should be more than enough.
I have avoided 21v as the datasheet says 12v, but what the hell, might as well give it a go !
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
usually any chip that needs 21V is does fine
2716 needs 25V and this programmer does not have that option as its restricted to 21V
which is will step-up to just fine
i personally have not been able to program 2716 chips with it but my otehr programmer does it
whct you might want to do is invest in some 2816 chips which are EEPROM equivalent to 2716 and are more reliable anyway being FLASH
tronads
455CR
You beauty !, 21V did the trick on the known good eprom. reads back exactly as it should.
STUPID HITACHI DATASHEET. 12.5v tut.
Thanks guys.
tronads
455CR
I do need to buy a couple though, one of the chips had a broken pin and a makeshift bit of solder and a diy leg on it.... and the first one is likely duff with its stuck high bit 5 on the databus.
So if you would like to sell me 2 or 3, I'd be most grateful.
Arch
9 (100%)
122CR
Ok, in a way it is good to hear that it really does not really handle 2716s, as I have been pulling my hair trying to burn them to repair my Stratovox board. I thought my USB output was low, so I even bought an external USB hub with a psu to no avail.
