EPROM PULLING - best tool?
Sbdesign
SEGA collector
16 (100%)
1,721CR
I have always used a screwdriver, but have many times bent pins.
Im considering stripping a house the dead rom board, to try the roms on a touring car rom board....
I thought best to get a tool, as there is so many....
Whats the tool of choice?
thanks
Lurch666
21 (100%)
4,518CR
I find a screwdriver used slowly at both ends of the eprom so It lifts a little each time works best.
Pulling tools that grip both ends tend to damage the eprom as it will suddenly pry lose at one end bending the pins on the other end.
So I would keep using a screwdriver but be careful and slow.
iamjimmi
498CR
Interesting to see what folk recommend...
I did try a chip puller (not a fancy as the one in the link above) and found it to be a total waste of time... chips would spring out bending legs in the process.
I had much better results using a small flat blade screwdriver... prising up each side gradually.
However, I am now mostly using a small pick. Something like this
https://www.amazon.co.uk/Silverline-427723-Pick-Hook-140/dp/B0015NRKDG/ref=mp_s_a_1_5?dchild=1&keywords=pick+tool&qid=1617708757&sr=8-5
Same technique as a flat blade screwdriver...iamjimmi2021-04-06 12:36:12
jonhughes
1,156CR
I use both. I tend to twist the screw driver gently under the chip at both ends rather than lifting it upwards. Big flat screw driver for ROMs and RAMs and smaller for ICs.
I only use the those chip lifting tools when removing ICs from the PCB after desoldering them. You can use them on socketed chips but I tend to use my right hand for lifting the chip and left to steady it because they are more trouble than useful as previously mentioned. I never use the screw driver when removing desoldered chips because it famously busts the tracks beneath the chip.
Preference is a flat bladed screw driver but I also use an spoon where the handle is just the right size and thickness.
jonhughes
1,156CR
Sbdesign said:
Screw fix
these any good? and would do the job?
That’s a PLCC remover by the way, no good for IC chips or others.
This is the IC type remover I use
https://www.ebay.co.uk/itm/IC-Chip-Extractor-Circuit-PLCC-Mother-Board-Remover-Puller-Plier-PLCC-U-Type-Kit/313425453989?chn=ps&norover=1&mkevt=1&mkrid=710-134428-41853-0&mkcid=2&itemid=313425453989&targetid=1140163975569&device=m&mktype=pla&googleloc=9045242&campaignid=12125451092&mkgroupid=122515099331&rlsatarget=pla-1140163975569&abcId=9300480&merchantid=232687980&gclid=EAIaIQobChMIsamH38bp7wIVSertCh2TYwm2EAQYAyABEgKlNPD_BwE&pageci=6422e11b-58ec-4324-b7de-027e641c3a50jonhughes2021-04-06 12:53:37
Sbdesign
SEGA collector
16 (100%)
1,721CR
funny you say that, this afternoon a crow was fighting a pigeon in the yard.
looked out later and just feathers and what looked like a pigeon in the corner, upon checking, it was only a pigeon back connected to both wings and nothing more. Pretty horrific, didn't know they were so brutal. It ripped it clean in half, no chest, head or feet anywhere.
mysticmonk
1,051CR
That's a rough outcome for the pigeon. While we're eating sandwiches and laughing everything around us is locked in ultimate mortal Kombat.
Check out this video, it's so near-perfectly choreographed with the predator music (especially the latter half) that it's uncanny!
yorkshire_spam
765CR
Flat bladed screwdriver, leaver a little one end, then the other until it lifts out.
Looking to pick a wiha lifter up soon though. (probably my next order with a big supplier will include one now I know they exist!)
