Faulty PVM
Martinmorv
5CR
I have a Sony PVM 14m4e that has developed a fault.
I was attaching my Saturn to it via a SCART to BNC cable when the picture suddenly lost colour, and became distorted. Now whatever I plug into it, I get a very faint black and white image that scrolls from top right to bottom left.
The menus still display perfectly so I know the tube must be good.
Could anyone offer any advice or anyone offer repairs on these monitors?
Thanks ever so much
Martin
Brettster
1,276CR
Sounds like you have lost Sync or Ground, is your Scart to BNC cable one with a sync stripper chip built in?
can you try plugging in something else to one of the composite ports on the PVM?
Martinmorv
5CR
Hi, I tried the composite port and the display is the same, still grey and scrolling.
My SCART to bnc works okay on a second PVM that I have so there are no issues there.
Martinmorv
5CR
Yep I think so. Does anyone know if the internal parts are interchangeable between different models of PVM?
I really like my 14m4e. I also have a 14d6e and a 10” pvm. Can I rescue the broken one with parts from the others?
obcd
3,830CR
Maybe, maybe not. At some point internally they have to separate the sync signals from the video signal and separate the signal into the 3 primary RGB colors. The way you describe the fault it's almost as if the video signal is not reaching those circuits well. This could be due to a problem with the switches that select from which input the video is coming. If they use the same integrated circuits to do the job, those are interchangeble, no matter what size the monitor is. I doubt the pcb's will be identical and a pcb swap will be possible. What I think doesn't matter. You will need to open them to see if the internals are somewhat identical. If the positions of the connectors are different, you are likely out of luck as those are usually directly soldered to the pcb.
Martinmorv
5CR
Hi, thanks for that. I know there are arcade monitor repair people on here, but does anyone on here offer crt tv / pvm repairs?
