[FIXED] Bubble Bobble attract mode resets
RGP
Meeter & Greeter
2,039CR
I have a problem that I am hoping someone else has had or has a suggestion on how to try and track it down.
I was recently looking at a Bubble Bobble PCB for Andy which had got some graphics issues. I'll write up a separate repair log on that but after restoring the screen I noticed the game kept resetting during attract more but at different points.
The title screen shows then insert coin then the instructions screen starts and then it will either reset here or while bub jumps up and down at the top of the screen or will freeze while collecting the prizes and showing points, sometimes it will proceed to the first level and reset a few seconds into it.
Immediately I suspected a watchdog issue so I monitored the reset line on the primary CPU and it never changes, the reset line on the secondary CPU does toggle but that makes sense as the code sends a signal to the sub CPU via the bus to do this.
It's like the program counter becomes $0000 again.
I've checked the Roms, they all match to Super Bubble Bobble but the board has all the stamps and tags of an original and has the proper BB chip on it.
I've swapped all the PALs involved from my own board and they all present the same issue and the ones from Andy's board work absolutely fine on mine.
I've run a frankenboard setup with my CPU board and Andy's graphics board and it never resets, Andy's CPU with my graphics board and the issue is in the same place so I've ruled out the graphics board as I know the bus addresses the second board.
The issue happens from cold also which makes it harder to find.
I'm confused by the reset line on the main CPU not changing. If garbage was appearing on the bus and the CPU crashed then I'd see the watchdog kick in and reboot the CPU but that doesn't happen and the rom on the sub CPU is tied straight to the CPU.
Test mode doesn't work properly on this board, it comes up and says ram ok but none of the switch tests work and all the dips are reported as "L" - as this is a bootleg rom set I'm likely to think this is a red herring.
I can't swap my own Roms in for some reason but that might be some jumpers needing changing or something. Mine are 27512'a and I only have three,, Andy's has 4 x 27256's.
The board was previously fully working and has been used by many at the arcade.
Anyone had a similar issue with anything else?
RGP2015-09-17 01:02:23
obcd
3,830CR
You could take his chips, read the original contents, erase them and program them with your code or mame rom code.
It's a lot of work, I know.
RGP
Meeter & Greeter
2,039CR
It's a step that I've considered.
I was poking around the various bus transceivers and found that if I piggybacked the 245 on the work ram then the game shuts down completely and won't boot. This is odd behaviour.
My suspicions point in the direction of that 245 or the work ram chip (6264)
shep
378CR
Are you saying that a bootleg version is being run on an original BB board? Why is that?
I have seen Bootleg BB's crash in attract mode when running some versions of the Redux ROMs. I'm pretty sure the cause was checksums in the code detecting the hack. The game then stealth crashes later on so that it's not obvious where the checksumming is done. Have the ROMs been changed recently in any way? Another possibility is a flaky ROM causing the checksums to fail. I could also be off track completely but it's something to consider.
RGP
Meeter & Greeter
2,039CR
Done a bit more on this, I found a couple of solder holes around a few chips so i've reflowed those, I pulled and tested the 245 on the work ram and that's fine, i've socketed and tried a brand new one in its place and no change.
However, I read shep's comment above, and decided to try playing a game, I got through all of level 1 and just as it was about to scroll to level 2, a message appeared in the middle of the screen for a split second.
COMMON RAM ERROR
and reboot.
Is this the 6264 work ram?
RGP
Meeter & Greeter
2,039CR
I've tried swapping the ROMs over and the game doesn't work with 27512's installed.
This was fully working so its not the bootleg ROMs being on the board per-se (although one could be getting flaky). All verify just fine against the online tool.
RGP
Meeter & Greeter
2,039CR
B8 is set off, I switched it on and the title screen appears but without the TAITO copyright message and then reboots as it tries to enter attract so i've switched it back off and its doing its cycle.
I found that the resets aren't as random as I thought. There's a predictable repeat pattern to it after watching it do it a few times.
It will eventually crash with something like this:
Complete freeze.
For reference, this is Andy's board:
This is my board:
Sorry the pictures are a bit dim, waiting for some new bench lamps after re-arranging the workshop.
RGP
Meeter & Greeter
2,039CR
Sussed it.....
COMMON RAM ERROR led me to piggybacking a new chip on the 2016 @ IC16 and the reset points changed and then went away.
Chip replaced and game now running fine - with my limited Bubble Bobble playing ability.
Test mode still doesn't work properly,
I need to make a new test bench adaptor for BB so I can spread the board out better.
Will leave it on overnight but its not reset at all now.
RGP
Meeter & Greeter
2,039CR
Hurray Banana said:
Nice bit of diagnosing James.
How many hours a week are you spending on fault tracing and fixing now?
Thanks Eric
Hmmmm, not enough to get through the pile I have that's amassed. Some I'll farm out, some I'll do myself.
It's not everyday, I just have this "can't let go" problem when I get into a bug or board issue or anything and my planned "stop now and have food" ends up being several hours later.
For example, I spent about 4 hours finding the original graphics fault because the clock signals looked fine but were out of spec enough to screw it up. I then started tackling the reset issue and that's where the rest of the evening went until I stopped around 9pm to order some 6264's thinking it was those being the problem.
I just get lost in it. Same thing happened doing my TRON, nights went by until 6am when I just showered and went to work at 7.
Hurray Banana
2,766CR
I can relate to that one James, dog with a bone syndrome is a good and bad thing, but I'd rather have the mentality than not; I see what the un-inquiring mind is like every day and it's not pleasant.
