[FIXED] PacMan Ball LCD
48CR
Can anyone advise on who can repair this from my PacMan Ball pusher? A bit of history ...
It was working ok
Screen stated to go white - graphics and text were still visible but only from high or low angles
Screen now black - seems no power - pos surface mount fuse gone? Power still to rest of game
Cheers !
silversmurfer2016-12-11 20:51:58
48CR
so looking at what feeds this unit there is a single 6 pin molex carrying
red
green
blue
sync
gnd
12v
is there an easy way I can use an alternative panel / with an RGB input or is there other things to take into account ?
Namco are quoting £350 and for it to be shipped to Japan for 4-8 weeks for repair - seems a little steep ?
48CR
This is the model of the panel - however the interface board may be the problem only manufacturer stamp in ELNA and they seem to be a sewing machine outfit now
Panel Brand:SHARP
Panel Model:LQ070T5BG01
Panel Type:a-Si TFT-LCDPanel
Panel Size:7.0"
Resolution:480(RGB)×234
Display Mode:TN, Normally White, Transmissive
Brightness:300 cd/m2 (Typ.)
Contrast Ratio:60 : 1 (Min.) (Transmissive)
Display Colors:Full color
Response Rime:30/50 (Typ.)(Tr/Td) (ms)
Viewing Angle:65/65/40/65 (Typ.)(CR?5) (L/R/U/D)
Frequency:60Hz
Lamp Type:CCFL
Signal Interface:Analog RGB + Composite Video (NTSC/PAL)
Input Voltage:5.3/13/-16V (VSH/VGH/VGL)
obcd
3,830CR
That resolution (234 lines) looks like the kind of panels they use in video players.
Most are composite video in. Not sure if RGB is normally on those as well.
A common fault on such displays are the inverters for the CCFL lamps. It's strange you got that discoloration before it went black.
I have seen such displays with small SMD fuses on the pcb. If the capacitors starts to age, such fuse can blow, but again, that would simply cause the display to become black.
Normally, the internal electronics run on 5V or 3V3. Maybe you could check if such voltages are present on the board. It will likely have a regulator on the pcb to produce the voltage for it's electronics, as usually the supply voltage is 12V
48CR
OK so opened it up to check for anything obvious - there are 2 smt fuses and the 1amp (fuse2) has blown
also r46 and c27 don't look particularly healthy
What's peoples thoughts on this - I could look at the 1amp fuse - although with no smt experience i'm not sure what the best approach is - can I solder a replacement on the top or is that really hacky? :)
silversmurfer2016-11-26 23:37:08
48CR
Ok so got it working again with the aid of the following ..
7" lcd panel
https://www.amazon.co.uk/gp/product/B01FXRU6XA/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
GBS8200 converter
https://www.amazon.co.uk/gp/product/B012W1Z8CE/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1
Panel fits perfectly into the original surround - just need to tweak the colours a bit then it's all good - I may have a look at the original lcd controller but at least this get the game up and running for the christmas festivities !
