Fluke pod 6809 help
andrew96
899CR
Have just managed to work out the rom is perfect, the manual explains how to do a signature check on the rom as the sig is actually in the rom, with the 'fluke calc ROM sig.exe' it matches the rom so at this point I know the rom is OK, but can the processor in the pod read the rom, will find that out when I can get a working pod in place of the cpu!
andrew96
899CR
Ok hold on the pod!!!
Am getting closer (i think)
Prodding around the address and data lines, I discovered A0 low was around 2.5v, it never went down to zero like the other lines, now there is not much that could be loading the line! the 6532, but that's been eliminated, and the 74hc374 (U4) on the interface board. now removing U4 and the address line came back!
now the troubleshooter shows
so progress as pod is now communicating with troubleshooter! (chip is on the troubleshooter)
So U4 tested and perfect, so must be something with the UUTON line or ATSC
will go further with this later on.....
andrew962015-02-28 19:22:57
andrew96
899CR
wey hey!!
so what was the problem!!
well it very much seems someone had somekind of attempt to repair this before me!
they removed U4 and U7 from there sockets and somehow managed to put them back in the wrong places! (U3 has definitely been replaced)
so that was it! simple as that! but what a headache to find!!
