FlukeIDE windows 64bit?
yorkshire_spam
765CR
Ahhh sorry, I'll try sending a file and see if I get the same. I fired it up and used it to generate some sigs from rom files and stuff like that... didn't get round to sending to the fluke.
eggwheatis
cheers
65CR
No prob..I found this so it was a known issue..I haven't fired up FIDE for at least 15 years
https://pairlist7.pair.net/pipermail/techtoolslist/2014q3/001940.html
But it didn't work either...must be another solution 6 years later??
trm
2,877CR
9lc is dos real mode so isn't supported under x64. I'm pretty sure one of the guys on tech-tools list re-wrote it in C or C++ so it can be built for x64. If you search the tech tools archive for 9lc dos replacement you should find the fix.
DanP
Administrator
2,232CR
You can download a hacked 9LC.exe from here;
http://www.coinopflorida.com/fluke/
It needs you to have installed DosBox first before you can use it but it works very nicely with FIDE.
I'm using it on an x64 Windows VM running on my MacBook using the USB serial interface. It works a treat despite the many layers of virtual abstraction!
Good to see some old faces back in the game (even a little).
Dan
