desolder and isolate centre pin of HOT, add 40w lamp to pin 1 and ground- if it lights flyback is probably ok
but then you would have neded to prove your b+ before doing so, you can do that by isolating pin 3 of the flyback and adding the lamp onto the track leading to pin 3, if it lights and reads around 130vdc then b+ is probably ok
if all this sounds too much don't do it, you will make it worse and unlikely anyone will take on a bodged repair- i know i won't
